Tuesday, September 07, 2010 - 01:48 pm, by: Michael White(Zeph312)
Hey everyone, my surge tank next to radiator seems to have leaked, there is a nasty white foam around the seal, not the top part with the cap, but where the upper bit of plastic meets the lower. The level seems to of gone down a bit just enough that it does leak out anymore, I believe it has also resulted in the heater not pumping hot air when not moving.
Is this common? Can you fix the seal with anything? Or should I be looking for a new surge tank?
