  Soarer Central * Mechanical - V8 * Signal from ignitors but no pulse at top coil plug, please help Previous Previous    Next Next
Matthew Werner
jzz30 TT
Reg: 12-2006
Monday, November 15, 2010 - 06:35 pm, by:  Matthew Werner (Matto_888) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys, i tried hitching onto old threads to save making another one... but no answers yet.
I have fitted a 1uz to a hj tonner and had it running fine with a few wires hooked to the battery, i then wired these same wires up to some decent relays an fuses off the key and it ran good for bout a minute and then drop the r/h (driver's side) bank of 4 cyl's. i have no pulse at the plug to the coil and i have switched both ignitors around and i have pulse at the lower coil but still none at the top...
Ive checked 12v to the ignitors as well as ecu pulse and output pulse and i'm getting a similar pattern across both ignrs.
is there a device somewhere between the ignitors and the top coil???
Matt
Tom Richards
Wednesday, November 17, 2010 - 08:47 am, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
check for a broken wire from the ignitor to the coil.
Matthew Werner
jzz30 TT
Reg: 12-2006
Thursday, November 18, 2010 - 12:16 am, by:  Matthew Werner (Matto_888) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thus my question.... is it JUST a wire from the ignitor to the coil?? or is there like a suppressor or somethin of that kind of homosexual nature
Tom Richards
Thursday, November 18, 2010 - 07:18 am, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
my understanding is a wire. compare the readings from each ignitor to the appropriate coil
