Wednesday, January 05, 2011 - 11:26 am, by: Michael Mazzone(Mazzownya)
Hi everyone,
I've had a problem with my 91 V8 Soarer the past couple days. It runs ok when the car is cold but as it heats up it runs pretty bad. I can feel it missing particularly under light/normal acceleration, it's harder to notice when my foot is down. it misses when in neutral/park also. The first thing i did was replace the air filter (which was filthy) and tried an injector cleaner. as well as a few ECU resets. its probably running a bit better but it's still happening
I'm running it on BP ultimate. any ideas? Thanks in advance
Wednesday, January 05, 2011 - 11:50 am, by: Layton Molenaar(Rbdestroyer)
Try replacing your 02 sensor. It runs on a pre determined setting when cold and once up to a certain temperature it will start to read your exhaust gases. Could be it. Give it a crack..
Wednesday, January 05, 2011 - 12:48 pm, by: Michael Mazzone(Mazzownya)
ok thanks, happen to know where i can get one cheap? I just rang sprint and they want $152 for one, bit of a rip. all other places i tried didn't have any. repco, super cheap, autobarn.
Wednesday, January 05, 2011 - 07:28 pm, by: Brett Harrison(Bretto)
The v8 will run fine with the O2 sensors disconnected, so try that first. If not, try coil, I would would be looking at the one on the left bank, close to the exhaust manifold.
Wednesday, January 05, 2011 - 08:00 pm, by: Michael Mazzone(Mazzownya)
ok, i've replaced the O2 sensor behind the front right wheel arch. It's still running like a bag of when hot lol. So there's another O2 sensor? Whereabouts is that one, and the coil? As i'm sure this has been done millions of times before is there a link someone can direct me to? I'm still a bit of a newb to the soarers.
Thursday, January 06, 2011 - 12:57 pm, by: Michael Mazzone(Mazzownya)
ok, is there an easy way to disconnect the coil pack on top of the engine? it seems to be quite difficult to get to. i removed the output plug most of the way off from it (couldn't get it all the way off) and the engine note didn't change at all (shocked my self a few times lol) but i thought there might be some arcing between the output connector plugs so it might actually be acting like its still plugged in. I pulled the power from the other coil above the AC compressor and the engine died. I disconnected the AFM, nothing changed.
Saturday, January 08, 2011 - 04:07 am, by: Michael Mazzone(Mazzownya)
Ok, Thanks everyone, all fixed. I believe it was the leads. 3 of them tested open. I replaced all the spark plugs too. Now it's running so smooth. Awesome, have been driving it all night.
