  Soarer Central * Mechanical - V8 * Radiator needed in Perth Previous Previous    Next Next
Alex Dermedgoglou
wa
uzz32
Monday, February 14, 2011 - 05:06 pm, by:  Alex Dermedgoglou (Soarer32) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi All,
Wife complained that her uzz32 suddenly dropped in power. i started the car after it had cooled down.
I suspect good ol' soarer has a thermo cut out to stop people cooking the motor running it without water/oil. Anyway - needs a radiator core i suspect. dripping from bottom, all rubber pipes are fine - top tank replaced 5 years ago and no sign of leak there. So i am looking for good condition radiator 2nd hand or suggestions as to best place for recore/buy new
many thanks
alex
Stephen Shackleton
UZZ32
Reg: 01-2008
Monday, February 14, 2011 - 05:29 pm, by:  Stephen Shackleton (Shack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I would be inclined to take it to a Radiator specialist and get them to pressure test the cooling system to locate the leak in case it’s not the core.
Tom Richards
Monday, February 14, 2011 - 06:43 pm, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
do a search on "aluminun radiator"
Alex Dermedgoglou
wa
uzz32
Tuesday, February 15, 2011 - 02:48 pm, by:  Alex Dermedgoglou (Soarer32) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Guys,
Many thanks - i'll remove and try the local specialist first
cheers
