Monday, April 30, 2012 - 02:50 pm, by: Ashley Leach(Ashlar)
Sorry to bump an old thread but I have a very similar issue with mine at the moment:
**EDIT** Actually scratch that. Vibration happens 59km-68km regardless of gear. Definite feels like something kicking in as when the speed drops below 59km it disappears. Possibly happening over 68km but it's hard to tell because we have such roads here.
I can feel it in the steering wheel as well. It also seems intermittent, sometimes worse sometimes not but always there at 60kmph.
I was thinking Diff, Tailshaft or Gearbox, but now I'm thinking torque converter. So whats the best course of action? Take it up to MV auto's and let them have a look?
What about you Christian?
Thursday, May 03, 2012 - 03:57 pm, by: Ross Pesina(Ross79)
I'm getting the same; kind of a pulsing vibration between 50 and 60km/h. About to inspect rubbers on tailshaft.
Also while cruising at 110km/h on the freeway in overdrive, occasionally I get a sudden missfire. Only happens when going up a hill. I installed new spark plugs, coilpacks, spark leads and its still happening. Could it be an issue with the auto?
Thursday, May 03, 2012 - 04:15 pm, by: Ashley Leach(Ashlar)
Ross,
I'll let you know how I go, Im going to be moving some wheels around, replacing the trans mount (I KNOW this needs to be done) and I'll inspect the rubbers while I'm under there. Failing that I'll just replace the transmission with another one. I plan on taking it in for a wheel alignment and balance as well.
The misfire, if all the stuff has been replaced. I'd say Fuel Pump or Fuel Pump ECU or Main ECU
Ross Pesina DieHard Vic Soarer V8, Soarer T, Soarer TT, Supra TT.
Friday, May 04, 2012 - 10:25 am, by: Ross Pesina(Ross79)
Thanks Ashley, keep me posted, I'll put my findings in here too. I have changed wheels which made no difference. Had wheel alignment checked, etc.
In relation to the missfire, I installed a new fuel filter and new fuel pump only last week which made no difference. I also swapped ECU which too had no effect.
