Tuesday, April 26, 2011 - 06:31 pm, by: Mitch Hughes(Aitch)
Hello all, I have recently removed the IAC off of my soarer as it has been having a looping idle issue, and am stuck at the point of removing seized bearing from inside the unit. I currently have it sitting in a tin can covered in CRC and am at a loss as to how to remove the bearings without causing damage to the unit? Any help would be appreciated.
Tuesday, April 26, 2011 - 09:02 pm, by: Mitch Hughes(Aitch)
Yer its the larger bottom bearing that is stuck in real tight. I used that other guide to help me get it out, but am unsure of how you tap out a bearing with a socket?
