  Soarer Central * Mechanical - V8 * Gates or Dayco timing belts Previous Previous    Next Next
Fran Valdivia
Wollongong NSW
Celsior
Reg: 01-2007
Monday, May 16, 2011 - 05:37 pm, by:  Fran Valdivia (Silvasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Gates or Dayco for Timing belt??
Just wanted some insight as to which is the better brand as well as the most cost effective.
Dayco has a complete kit which comes with a hydraulic tensioner, the Gates kit does not.
Any opinions?
Damian Ware
UZZ32
Tuesday, May 17, 2011 - 08:06 am, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Gates is a top quality brand. Dayco is a budget quality brand.
If this is for a 1uz OEM timing belt is the best option as it is cheaper than most aftermarket belts and has timing marks which most aftermarket belts don't have.
Fran Valdivia
Wollongong NSW
Celsior
Reg: 01-2007
Tuesday, May 17, 2011 - 06:20 pm, by:  Fran Valdivia (Silvasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It is for a 1UZ, so you recommend OEM, cool thanks.
Do you know if they come in kits, ie pulleys, seals, etc
Nathan Smith
Reg: 04-2009
Tuesday, May 17, 2011 - 08:38 pm, by:  Nathan Smith (Zanjara) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you dont get the oem belt i would get the gates timing belt. The gates is pretty much the same as the oem belt. The dayco timing belts are not all that good. In some cars the dayco timing belts are out by 1 tooth.
Morris Salza
UZZ31 V8
Reg: 04-2011
Wednesday, May 18, 2011 - 07:22 am, by:  Morris Salza (Itongo71) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have a dayco belt on my 1uz, and although I agree the gates is a high quality belt, I have had no issues with mine. I agree that the oem belt would be the better option. Recently I asked my Toyota dealer if they supplied a kit and they said they don't, but can supply everything separately. I will be using oem parts when I change my belt. I would also recommend replacing your water pump while you have it all apart, makes sense. Good luck.
Wednesday, May 18, 2011 - 03:52 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I recently bought these OEM bits from CMI Toyota Adelaide for the 1UZ.
Water Pump - $161.12
Timing Belt - $65.46
Tensioner - $104.61
Serpentine Belt - $41.53
Total - $372.72 + GST = $410 ($0.01 rounding)
Fran Valdivia
Wollongong NSW
Celsior
Reg: 01-2007
Wednesday, May 18, 2011 - 07:00 pm, by:  Fran Valdivia (Silvasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Nathan, Morris and Peter for the price listing :-)
