  Soarer Central * Mechanical - V8 * Torsen diff Previous Previous    Next Next
Scott Harris
uzz30 v8
Reg: 04-2007
Wednesday, August 03, 2011 - 04:19 pm, by:  Scott Harris (Scottuzz30) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hi all this may seem a stupid question but thought what better place to get info on a soarer problem.
I need a new diff and currently have just the stock one fitted, will a torsen diff go straight in without any problems< and what sort of price am i looking at for this kind of repair? the car is a 93 V8 auto. Any help would be greatly appreciated. Thank you
Matt Petersen
NA
Reg: 01-2008
Wednesday, August 03, 2011 - 04:30 pm, by:  Matt Petersen (Mattmannz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There is quite a bit of information on here and Supraforums and other sites about the JZZ/JZA/UZZ diffs and ratios.
The short answer is that a Torsen will fit however finding a Torsen with your current 3.9 ratio is very unlikely.
I swapped in a JZA80 4.1 Torsen and it's a great upgrade. Increases RPM's by about 200 RPM at 100k's which is no great drama.
Matt
