Thursday, February 02, 2012 - 11:07 am, by: Arnya Simpson(Arnie)
Hi guys,
I washed my car on the weekend, and ever since, the car has been shaking severely and it appears the electrics are intermittently getting a short/cutting out? As when the car shakes (does it while idling mostly, however accelerates a little dodgey also) the TEMS SPORT light on the dash flickers/dims at the same time. The aircon also stopped working this morning!! (I HOPE this is just the buttons on & around the EMV that are stopping it from working)
After a 10 minute drive, the car seems to sort itself out (apart from the aircon now) and go back to normal.
Thursday, February 02, 2012 - 08:37 pm, by: Nathan Richardson(Richtheblack)
Remove the cover that says V8 Four Cam 32 (Passenger Side, most likely to get filled with water).
Pull the leads off the plugs and use compressed air to blow the water out. If you don't have an air compressor, you can get "Air Duster" cans from Bunnings.
