  Soarer Central * Mechanical - V8 * ECU Repair Previous Previous    Next Next
Peter Scott
qld
UZZ31 Limited V8
Reg: 08-2008
Wednesday, April 11, 2012 - 08:35 pm, by:  Peter Scott (Scotty) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi anyone have Damian Ware or Christian Molenda Phone no, so i can contact them to get a postal address, to send my ECU to be repaired Please. Thanks.
David Eberhart
Q.L.D.
Reg: 07-2007
Thursday, April 12, 2012 - 12:08 am, by:  David Eberhart (Orphan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Are you referring to having the capacitors replaced? If so I had my ecu and dash done by a guy in South Brisbane (Archerfield). He has done a lot of Toyota ecus. PM me if you want more details.
Peter Scott
qld
UZZ31 Limited V8
Reg: 08-2008
Thursday, April 12, 2012 - 07:40 am, by:  Peter Scott (Scotty) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Dave i have sent you a PM. My V8 has 2 injectors jammed open so the injector drivers in the Ecu must be shot. Thanks for your help. I would still like to get in contact with Damian and Christian.
Thursday, April 12, 2012 - 07:00 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Might not be the drivers. I had the same problem, replacing the caps fixed it.
Rick Slav
Waikato
Reg: 01-2009
Tuesday, August 07, 2012 - 04:25 pm, by:  Rick Slav (V8soarernz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Peter Scott, did you get it sorted. What was the problem in the end? My 31 sounds like it has the same issue as yours.
