  Soarer Central * Mechanical - V8 * Single Turbo 1uz in HQ tonner Previous Previous    Next Next
Matthew Werner
jzz30 T
Reg: 12-2006
Wednesday, September 19, 2012 - 10:55 pm, by:  Matthew Werner (Matto_888) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey guys,
did a search and scanned through the threads, looking in the 3 other threads bout turbo v8's an didn get my answer, hence starting this thread...
i have a t04z mounted on the front of the motor where the radiator fan hydraulic pump used to be, its an alloy spider looking mount around the timing belt..
i wanna know, if i bolt the t4 flange on a mounting plate (10mm thick plate) to support the turbo instead of relying on the exhaust pipes soley, will the heat from the turbo end up melting that alloy?? i will have heat shielding every effin' where of course. pics to follow
Matthew Werner
jzz30 T
Reg: 12-2006
Wednesday, September 19, 2012 - 11:17 pm, by:  Matthew Werner (Matto_888) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ali Saeed
'97 JZZ30, '12 ZN6
Wednesday, September 19, 2012 - 11:31 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i wouldnt mount it there...the belts and hoses will get brittle..
Matthew Werner
jzz30 T
Reg: 12-2006
Thursday, September 20, 2012 - 12:07 pm, by:  Matthew Werner (Matto_888) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for the prompt reply Ali :-) ,
the zorst will be heat wrapped where it goes near the belt.. and the wires for sensors and what not will be shielded as well, im not overly worried bout the radiator hose as they're fairly good with heat, so the turbo cozy should do alright there, im more looking at heat transfer through my bracket into the alloy bracket around the timing belt..
i would like to hear peoples theory's on what heat transfer effects i might come across..
Ali Saeed
'97 JZZ30, '12 ZN6
Thursday, September 20, 2012 - 12:26 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Can we have a look at a picture of the entire engine bay?
Matthew Werner
jzz30 T
Reg: 12-2006
Friday, September 21, 2012 - 12:09 pm, by:  Matthew Werner (Matto_888) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yea sure, ill take some this arvo :-)
Matthew Werner
jzz30 T
Reg: 12-2006
Friday, September 21, 2012 - 07:09 pm, by:  Matthew Werner (Matto_888) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Matthew Werner
jzz30 T
Reg: 12-2006
Friday, September 21, 2012 - 07:11 pm, by:  Matthew Werner (Matto_888) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ali Saeed
'97 JZZ30, '12 ZN6
Friday, September 21, 2012 - 10:52 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
In my opinion, put the battery in the back and the turbo where the battery is
Paul Drane
Saturday, September 22, 2012 - 06:52 am, by:  Paul Drane (Paulwd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I am with Ali on this, even with heat shielding , its to close.
maybe do something like this, HQ Monaro
Kurt Atzmuller
TT`s
Reg: 05-2011
Saturday, September 22, 2012 - 08:57 am, by:  Kurt Atzmuller (Kurt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Looks like it would be a tight squeeze where the battery is also.
Great project Mathew hope you sort it all out!
Matthew Werner
jzz30 T
Reg: 12-2006
Saturday, September 22, 2012 - 11:35 am, by:  Matthew Werner (Matto_888) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yes i originally wanted to put it where the battery is, but i really need to mount the turbo with a bracket to the motor because of the manifold type, they wont support the weight and temp changes without cracking.
ill revise and sink a few JD's over my pondering and come back with another option later.. thanks guys
Saturday, September 22, 2012 - 08:24 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
All that exhaust heat will kill the belts and wiring on the front of the engine that close .
Single turbo slightly to one side of engine will work well . Pipes don't need to be equal length . Just run some log style manifolds , or turn the factory ones upside down and swap sides .
Matthew Werner
jzz30 T
Reg: 12-2006
Sunday, September 23, 2012 - 09:45 am, by:  Matthew Werner (Matto_888) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks Daniel :-)
yea i had a suss and itll fit where the battery is, only thing im worried bout is pipe flex and movement when the engine loads up ,
ill make a bracket and post some pics later this week..
Sunday, September 23, 2012 - 06:09 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Will be fine . Just fab a bracket to mount where the original bracket tray is if needed . But most won't break , you'd be surprised .
But any bracket would work .
Matthew Werner
jzz30 T
Reg: 12-2006
Tuesday, September 25, 2012 - 05:30 pm, by:  Matthew Werner (Matto_888) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ermm, did i forget to mention that 'I' made them.. from standard log manifolds welded to bits of pre bought bends and straights haha.. it will definately need to be braced hehe
Ali Saeed
'97 JZZ30, '12 ZN6
Tuesday, September 25, 2012 - 06:45 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
depends on the thickness of steel + quality of welds. Stock manifolds are heavy cast pieces so they will hold the turbo quite well
Allan Langford
Reg: 05-2010
Tuesday, September 25, 2012 - 08:05 pm, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
why not put the turbo under the tray and run some nice headers?
Matthew Werner
jzz30 T
Reg: 12-2006
Wednesday, September 26, 2012 - 09:01 pm, by:  Matthew Werner (Matto_888) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
im not a big fan of remote mounted turbos.. mind you ive never had anything to do with them.. but they just dont get me hard...
popping the hood and seeing a dirty big snail jumping out and slapping you in the face, floats my boat nicely..
