  Soarer Central * Mechanical - V8 * V8 Oil Filler Previous Previous    Next Next
Darren Bruce
Reg: 07-2011
Saturday, August 10, 2013 - 03:39 pm, by:  Darren Bruce (Daz666) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
My oil cap seems to have come detached? The Top (the bit you grip) comes off by itself leaving the bottom section impossible to remove. Can this be glued back together?
I notice a guy needing a cap in the 'wanted' section has had no replies. So it seems the caps are not readily available?
So back to my original question... Can it be glued?
Mark Peters
Soarer UZ31 Ltd, 77 Mini Clubman Estate
Reg: 10-2009
Sunday, August 11, 2013 - 12:25 am, by:  Mark Peters (Honky) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you go down to your local Repco or Super Cheap Auto and tell them what model car you have they will find one for you. I had mine come off once and i lost it. Not sure how, but they should have generic looking replacements. Mine cost about $10 or so.
Michael James
V8 UZZ31 Limited
Tuesday, August 13, 2013 - 06:33 pm, by:  Michael James (Wildwizard) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Seems like it's ~$9 + postage
http://www.amayama.com/search/?q=12180-50010&cur=AUD
