  Soarer Central * Mechanical - V8 * Higher temp than normal thermostat for a V8 Previous Previous    Next Next
Open in new windowArchive through August 23, 2013Blake Gloyn25
Open in new windowArchive through October 20, 2013David Lye25
Ali Saeed
RSP JZZ30
Sunday, October 20, 2013 - 10:39 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Soarer OBD ports cant be read by an average mechanic.
Matthew Salkeld
1JZ powered 180sx
Reg: 07-2008
Monday, October 21, 2013 - 06:50 am, by:  Matthew Salkeld (Munkymatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ah right I've just read up on it... only the vvti 1J's are OBD2... For you it's easier, no tools required... just close the test circuit and read error messages off the dash. Have you done that yet? Others might have called it "reading error codes" or something...
John Stafford
Qld.
Soarer UZZ31 GT-L V8 and a UZZ32 # 514
Reg: 02-2010
Monday, October 21, 2013 - 08:44 am, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
When I try to do a diagnostic and join either TE1 and E1 or E1 and TC and TS (it seems like either of these are fine for diagnostics) I just get the blinking on the dash and then a message in Japanese like: ... TPJ and E1 but not quite, that is an effort to match the Japanese.
What does that mean?
Nothing else comes up?
What am I doing wrong or is that telling me that there is nothing wrong?
Tom Richards
Monday, October 21, 2013 - 10:56 am, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i think you press 2 buttons on the emv to get the readout.
Tom Richards
Monday, October 21, 2013 - 11:03 am, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://soarercentral.com/sc-forum/messages/1113/1392.html?1104486870
