  Soarer Central * Mechanical - V8 * V8 Engine Whine Previous Previous    Next Next
Neville Smith
Reg: 02-2008
Monday, July 21, 2014 - 10:58 am, by:  Neville Smith (Arawa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
New noise, came on suddenly, happens whether engine is hot or cold, varies with revs. There's a bit of a grumble from some of the serpentine belt pulleys but the whine is a different sound. Fluid levels are normal and it's not the suspension compressor. Timing belt etc was done within the last year. Any ideas before I take it to the local mechanic?
Tom Richards
Monday, July 21, 2014 - 01:29 pm, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
alternator rectifier assy has failed diodes???
Do you also hear a whine thru the radio?
Neville Smith
Reg: 02-2008
Monday, July 21, 2014 - 05:19 pm, by:  Neville Smith (Arawa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Tom - I'll check that tomorrow, but I haven't noticed it so far.
Monday, July 21, 2014 - 05:31 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
AC compressor?
Robert Day
v8 & TT
Reg: 01-2007
Monday, July 21, 2014 - 09:41 pm, by:  Robert Day (Lexsmaz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Take the serpentine belt off & run it then to see if the noise has gone & obviously if it has gone its in one of the Ancillaries & if still there could be the water pump or idler pulleys for the cam belt ..
Neville Smith
Reg: 02-2008
Tuesday, July 22, 2014 - 02:41 pm, by:  Neville Smith (Arawa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Strange - no noises at all today. What other symptoms might I see if it is rectifier diodes - low charge voltage?
Tom Richards
Tuesday, July 22, 2014 - 02:55 pm, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
low charge.
( $75 for a new rectifier assy)
Neville Smith
Reg: 02-2008
Thursday, July 24, 2014 - 10:18 pm, by:  Neville Smith (Arawa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Bloody noise hasn't come back. But I bet it will.
Neville Smith
Reg: 02-2008
Tuesday, August 12, 2014 - 12:28 pm, by:  Neville Smith (Arawa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Aha, back again. Further symptoms have developed - 'battery not charging' Klingon plus cat warning light, but only intermittently, usually under heavy acceleration. I figure this is probably the rectifier diode problem you diagnosed, Tom. Radio whine on distant stations too. Alternator is out of the car now so looking for a p/n for the rectifier assy.
Although, the alternator does charge at 14+ volts, dropping to 12.8 or so after a while. Seems inconsistent with a diode problem when I think about it.
Tom Richards
Tuesday, August 12, 2014 - 01:12 pm, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
contact david at
http://stores.ebay.com.au/startercenter/
tell him it is for a denso in a V8 soarer
a rectifier assy is ~$75 delivered.
Rob Charles
Reg: 07-2014
Tuesday, August 12, 2014 - 01:13 pm, by:  Rob Charles (Pearl_white) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Toyota in Burnside Victoria will fit an alternator for $100.
A new alternator and fit costs $300 i believe.
- Spoke to them weeks ago.
http://www.biptoyota.com.au/contact.html
Cheaper to rebuild it if you know what you're doing however - as you probably figured out.
Good luck!
Tom Richards
Tuesday, August 12, 2014 - 01:50 pm, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
you are better off repairing the original Denso alternator. It's performance is way better than a replacement
Jamie Richards
St.john's
v8
Reg: 06-2009
Wednesday, August 13, 2014 - 01:37 am, by:  Jamie Richards (Nwb40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I need a rotor for my original denso alternator
Tom Richards
Wednesday, August 13, 2014 - 07:19 am, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
contact david at
Neville Smith
Reg: 02-2008
Wednesday, August 13, 2014 - 09:36 am, by:  Neville Smith (Arawa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well, definitely a diode problem. The rectifier recommended by David is shown as Not Compatible in his own website, so waiting on a further response from him on that. Have identified what looks like the right rectifier assy from Denso, but it has 8 diodes whereas the original has only 6, although the mounting plate is set up to take 8. Anyone want to give me an opinion of the risk in putting an 8 diode unit in?
Tom Richards
Wednesday, August 13, 2014 - 09:59 am, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
the correct rectifier unit was not listed on the web site when i purchased one in mid 2013. David is very familar with the alternators and told me what pn i needed. ~$70 delivered, works great no issues, easy to change. I would trust david to supply the correct part from the info you give him, V8 soarer, denso alternator, 199?.
Neville Smith
Reg: 02-2008
Sunday, August 17, 2014 - 08:38 pm, by:  Neville Smith (Arawa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Tom, new diode block fitted and all is good. I'm pretty impressed with such an accurate diagnosis based on minimal symptoms - did the same thing happen to you?
Tom Richards
Sunday, August 17, 2014 - 08:51 pm, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hi neville, i had the whine in the radio that was in sync with revs. made an "educated" guess that 1 phase was missing in the alternator. New diode assy fault fixed. Happy I could point you in the right direction. Thks for the feedback.
