1
3
7
Days
Search
Topics
Tree View
Help
Soarer Central
Mechanical - V8
Dammit. TPS screw is wonky.
Previous
Next
Author
Message
Rob Charles
Reg: 07-2014
Rating: N/A
Votes: 0 (
Vote!
Wednesday, January 07, 2015 - 03:15 pm, by:
Rob Charles
(Pearl_white)
How do you get a screw out - a screw holding the tps - if a screwdriver has ruined the tip?
inserted a screwdriver today - turned it gently - and the thing threaded itself.
Now it's a giant circle instead of a star after one single turn.
sigh.
Pointers please.
Just found this...
http://www.ehow.com/how_5127433_use-easy-outs.html
Any better ideas?
Rating: N/A
Votes: 0 (
Vote!
Friday, January 16, 2015 - 01:28 am, by:
(Pen)
I got an Easy-out that is a double ended drill bit.
One end is used to drill a small hole in the screw, the other end is then used to remove the screw. Use very slow speed.
Works well.
Rob Charles
Reg: 07-2014
Rating: N/A
Votes: 0 (
Vote!
Friday, January 16, 2015 - 03:21 pm, by:
Rob Charles
(Pearl_white)
Hi guys, thanks for the reply Peter.
I got it out with this method.
1. Get a flat rubber band.
2. Place it over screwdriver tip.
3. Unscrew TPS as normal.
The rubber band filled in the gaps caused by the wonky screw, it turned fine with a smaller diameter screwdriver.
Phew!
-Color-
Black
Red
Green
Blue
Yellow
Purple
Orange
Cyan
Gray
White
-Font-
Arial
Courier
Symbol
Times
Verdana
-Size-
Smallest (-2)
Small (-1)
Normal
Large (+1)
Largest (+2)
Username:
Important Posting Information:
Administration
Log Out
Previous
Next
