Thursday, January 08, 2015 - 01:19 pm, by: Patrick Fenis(Soarer_beast)
Hi forum fiends!
If the speed limiter is removed, does the digital dash read higher than 180km/h if you are going faster than 180km/h ? Or will it stay at 180km/h even if you are doing 250km/h?
How accurate in general is the digital speedo compared to analog? What are the major issues that arise?
Thursday, January 08, 2015 - 01:41 pm, by: Robert Day(Lexsmaz)
If the speed limiter is removed the speedo will still not read higher than 180 ..
In general Speedo's are allowed a plus or minus 10% from the Manufacturer when the car is new, usually quite bit better than that though & digital is probably better but still probably comes under the same 10% range when the car is new & again most read quite close to the correct speed, tyres & rims size will effect the reading though & in your case just use a GPS as a reference to see where yours is off, if at all ?? ..
