Monday, April 25, 2016 - 04:41 pm, by: Joel Hickey(Cp1joel)
Hi guys,
My sc400 has recently started stalling when placed into drive or reverse. Runs fine in park or neutral, but as soon as a gear is selected, it starts to run rough and stall.
If the car has been left and is cold, i am able to drive for a minute or so without it stalling.
After this, every time it will instantly idle rough and stall when put into gear.
Have bypassed the fuel pump ecu, have also checked the IAC valve and that is working fine.
Any ideas of what the problem could be ?
* In regards to the IAC valve, the bearings seemed to spin fine, but as suggested in another thread maybe they needed to be replaced?
Monday, April 25, 2016 - 08:07 pm, by: Dan Newton(Danbad)
Hi Joel, at an educated guess I'd suggest one of the solenoids is shagged, but running ect diagnostics will confirm. If you're unsure how to do so there's a ton of tutorials available.
