  Soarer Central * Mechanical - V8 * 91 sc400 miss firing on low revs Previous Previous    Next Next
Diane Jones
91 V8
Reg: 09-2016
Friday, September 30, 2016 - 03:47 pm, by:  Diane Jones (Blwlta) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Miss firing on low revs comes back to life around 3half grand also has a slight miss on idle but not all the time any help please
John Street
Supercharged 95 v8 , 2015 VW Jetta TDI, 2009 Saab 9-3 Turbo
Friday, September 30, 2016 - 04:01 pm, by:  John Street (Rex2ce) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Any recent work done?
Diane Jones
91 V8
Reg: 09-2016
Friday, September 30, 2016 - 04:08 pm, by:  Diane Jones (Blwlta) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No none fine 1 minute miss firing the next has run perfect 4 months now this hour ago
Diane Jones
91 V8
Reg: 09-2016
Sunday, October 02, 2016 - 07:26 am, by:  Diane Jones (Blwlta) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anyone shed some light on this or has anyone had the issue before
Ross Pesina
Soarer T, Mk3 Supra TT, Mk4 Supra TT, Z32 TT
Reg: 08-2006
Sunday, October 02, 2016 - 10:59 am, by:  Ross Pesina (Ross79) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The happened once to my mum's car after pressure washing the engine bay and a bit of water got to the spark plug area. It was doing it for around a week.
When did it last have a major service?? If so do you have a full report of what was replaced?
Go over the most likely causes; Spark plugs, leads, Coil packs, rotor caps and buttons. I have seen some pretty rough looking contacts on the rotor caps due to never being replaced.
Diane Jones
91 V8
Reg: 09-2016
Sunday, October 02, 2016 - 12:51 pm, by:  Diane Jones (Blwlta) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cheers mate I'll check a few things its not coiled I no that
Diane Jones
91 V8
Reg: 09-2016
Sunday, October 02, 2016 - 01:27 pm, by:  Diane Jones (Blwlta) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Unplugged the AFM runs fine plug it back in runs with a miss? Anyone had this problem
Ross Pesina
Reg: 08-2006
Monday, October 03, 2016 - 12:46 am, by:  Ross Pesina (Ross79) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I had that happen with my first V8 soarer ended up replacing AFM and fixed the problem.
First I'd try an airflow meter cleaner from supercheap:
http://www.supercheapauto.com.au/Product/CRC-Mass-Air-Flow-Sensor-Cleaner-300g/157339?utm_source=sho p_search&utm_medium=search_results&utm_campaign=g_shopping&gclid=Cj0KEQjw4MK_BRC1n6KTtezikbIBEiQA872 hYWpa01huXcIbe6-NyBRw1qGw32I4_JZh3CgAl8tIPrMaAql_8P8HAQ
Raoul Duke
Soarer UZZ31 V8
Reg: 09-2016
Tuesday, November 01, 2016 - 06:33 pm, by:  Raoul Duke (Hunter) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Don't use MAF cleaner if you have Karmen Vortex MAF or you will destroy it apparently.
Uzz31 has Karmen Vortex I believe.
