  Soarer Central * Mechanical - V8 * 1uz power steering Previous Previous    Next Next
Shane Henry
84 Supra soon to be V8
Reg: 05-2006
Wednesday, May 24, 2006 - 05:41 pm, by:  Shane Henry (Dallamar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Can the 1uz run without the power steering pump? If so what belt would I use and how would it be configured?
Thursday, May 25, 2006 - 03:51 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Why would you want to? The steering will be VERY heavy, plus it's illegal I believe. Though I notice you are trying to fit it to a Supra which might be a bit different.
The front belt (unless the engine is from a UZZ32 which gas 2 belts) drives the P/S pump as well as the A/C and alternator.
Whoever is the architect of your engine swap should be able to work things like this out for you.
Phil Gibson
'94 black/black UZZ31
Thursday, May 25, 2006 - 09:47 am, by:  Phil Gibson (Sciflyer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
This can be done, i know of a 1uz that was put in an old holden ute, as the ute didnt have PS the internals were removed from the 1uz pump and the ports blocked up so in effect it was just freewheeling on the belt. Its not hard to do.
Matthew Werner
jzz30 TT
Reg: 12-2006
Wednesday, June 30, 2010 - 09:55 pm, by:  Matthew Werner (Matto_888) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
wat is this marvel u speak of phil... i too am attempting the 1uz into tonner build... would be nice to chat to someone whose 'been there' so to speak.....
Thursday, July 01, 2010 - 06:03 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I ran the pump dry for ages on the drag engine, didn't seem to hurt it either, as I installed it on a customers car after I had removed it ! I didn't even plug the holes, just drained it.
Matt,
Why not do a Rack Conversion and run the pump !
Thursday, July 01, 2010 - 06:10 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Matt,
Forget the rack conversion, a quick search found it to be $2,750............ouch.
Matthew Werner
jzz30 TT
Reg: 12-2006
Thursday, July 01, 2010 - 07:24 pm, by:  Matthew Werner (Matto_888) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
geez Neil... trying ta make things more complicated haha ha... im going to be flat out figuring out which way up the engine should be mounted...
i hope that customer doesn have issues haha
Aiden Cheese
Soarer jzz30
Reg: 09-2009
Friday, July 02, 2010 - 07:22 pm, by:  Aiden Cheese (Chillpen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
the 260z which we put the 1jz has no power steering rack so we just gutted the internals of the power steering pump and plumbed it into itself.
Unless its fouling on something I'd suggest to leave it in and gut it like ours. Plumb it into itself and that way it won't break down.
Matthew Werner
jzz30 TT
Reg: 12-2006
Friday, July 02, 2010 - 08:57 pm, by:  Matthew Werner (Matto_888) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
wat about removing the pump all together and running a smaller belt... would it be possible to route the belt straight to the tensioner from the top idler... and then straight from the alt back to the crank?? looking at pics.. depending which way the tensioner operates, You could route it over the top or under it straight through from top idler to alt.....
