  Soarer Central * Mechanical - V8 * SUS NG code 73 and TRC NG code 46 Previous Previous    Next Next
Elizabeth Hogan
western australia
V8 Limited edition
Tuesday, July 25, 2006 - 11:34 am, by:  Elizabeth Hogan (Snowcatz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Can anyone tell me what these codes are .
SUS 73 and TRC 46.
Abs OK
Liz
Dave Hart
Waikato
UZZ32
Tuesday, July 25, 2006 - 01:01 pm, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The ABS and TRC are very much interlinked and I'd be very surprised to find that the TRC is at fault and the ABS is ok. The ABS usually takes out the TRC and not the other way round.
John Street
Tuesday, July 25, 2006 - 07:33 pm, by:  John Street (Rex2ce) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Liz,
SUS n/g 73 means "insufficient suspension compressor pump current". Run diagnostics with the engine running and this code should not appear, as happened with my car.
