Goo Roo ACT V8 Ltd manual
Posts: 2392 Reg: 07-2005
| Factory Torsen LSD is (was) available for the V8 as an option. I have one and so do a very few other people. You can see that it is an option in the site to which Ali referred. http://english.auto.vl.ru/catalog/toyota/soarer/1994_1/5899/ That Russian site has the same information in the same format as www.amayama.com |
Ashley Leach
TryHard South Australia UZZ31 V8 GT Limited (it's louder than Pen's)
Posts: 267 Reg: 02-2006
Sean Willenberg wrote on Friday, September 08, 2006 - 08:44 am:All in all, Soarers Kick Ass!
Hell yeah! Especially if you have headers and a decent exhaust, it not only looks impressive it sounds awesome too. |
Tim Appleton
TryHard QLD UZZ31
Posts: 291 Reg: 07-2005
| I hear ya brother!! Except I need headers... |
Ashley Leach
Posts: 268 Reg: 02-2006
| When you get them, spend the $$$ and get them ceramic coated. |
Posts: 4583 Reg: 05-2005
| As David has said, LSD was indeed an option for V8's, and is designated by: A101B on your factory Toyota data plate.
Andre Banna
Tinkerer Vic Soarer v8
Posts: 11 Reg: 09-2006
| hey guys, iv read on planet soarer that straight through 2.5" pipes at the back and lukey straight through mufflers make a huge difference on the v8s??? what advice do you guys have on exhuasts?? |
Posts: 2398 Reg: 07-2005
| This guy has a few bits of advice, Andre: 1. Look under the topic "Mechanical V8" for a couple of threads with "exhaust" in the title 2. Search for exhaust 3. Try not to start a whole new thread within an existing one. This is different from drifting off topic where there is some associative path. My advice in direct answer to your question is in existing threads so I am not going to repeat it here. Hope this helps more than it might at first seem like it does.
Peter Chriss
TryHard vic limited V8
Posts: 105 Reg: 08-2005
| Yes Maurice that was what we put it down too. But iv been putting 96 ron and 98 and have taken it back several times to have them work on it(retune for moble 6000 wich is the only fuel I use now). In the end they burned out my new spark plugs,that have now been replaced and still very little gain in power and fuel econ also still a weird jump in power at 3500 to 4000 rpm. Iv given up for now till i find another tuner and time off. |
TryHard Victoria Twin Turbo
Posts: 234 Reg: 06-2006
| This wasn't APS in Croydon was it? Sorry to hear about all your problems! I got my car tuned (Emanage) and I noticed a huge difference in power all across the rev range, although still uses heaps of fuel when cruising. I'm a bit PO'd because part throttle was tuned, it's just not lean enough, still uses too much fuel. |
Tim Appleton
TryHard QLD UZZ31
Posts: 294 Reg: 07-2005
| You generally can't tune a piggyback for AFR on part throttle unless you disable the oxygen sensors (generally not a good idea and may confuse the ECU). |
Anish Varsani
TryHard QLD V8 UZZ30
Posts: 406 Reg: 07-2005
| You should be able to squeeze a few degrees of timing in. Provided you don't push it too far, you won't destroy plugs. If you go a heat range colder on the plugs, you can get 10 degrees of timing at WOT without destroying plugs or pinging. Will dramatically improve throttle response and improve cruise economy slightly (about 8%). |
Phil Gibson
DieHard WA '94 black/black UZZ31
Posts: 671 Reg: 07-2005
| LSD was not available on V8s at all before 1994.... |
Peter Chriss
Posts: 106 Reg: 08-2005
| It was technik tuning thornbury recommended by the APS web site. Iv just changed back to the V8 ratio diff and i can hardly get wheel spin even with the foot on the break. Im not really into doing burnout or doughnuts (any more) but mine would have no chance. Out of a tank of fuel be for unichip 560 to 580km depending on how i drive now 590 to 610km. I just love V8s to much and would never trade for turbo. (Unless it was V8 turbo then maybe) |
Nick Red
Tinkerer rotorua v8
Posts: 12 Reg: 08-2006
| i cant get mine to spin either unless its wet. I can do better burt outs in my mothers 87 auto corona. does a shift kit really help on the launches? |
Phil Gibson
Posts: 691 Reg: 07-2005
| What size wheels/tyres are you guys running? I can get wheelspin from mine pretty easy from a standing start, although thats on 235/17 tyres so not exactly wide for a Soarer. All i have is BFI and extractors, still stock exhaust. |
Nick Red
Tinkerer rotorua v8
Posts: 13 Reg: 08-2006
| i have 255 in back can people get the wheels spinning from standing still and no brake. i cant even get it to do it with the foot brake on |
DieHard NSW 94 UZZ31 (V8) / 96 JZZ30 (TT)
Posts: 725 Reg: 07-2005
| Put in N, rev it anywhere above 3000rpm, slam it into D and you should be burning up the road Can't say the gearbox will like it though hehe. |
Darryn Dewar
TryHard Gisborne UZZ30 Soarer
Posts: 367 Reg: 09-2005
| Why only 3000 rpm?? If you're trying to break things, mayas well go the whole hog |
Posts: 4616 Reg: 05-2005
Posts: 731 Reg: 07-2005
| I did say anywhere above 3000rpm How far you go, nobody knows! |
Nick Red
Tinkerer rotorua v8
Posts: 14 Reg: 08-2006
| well after all this talk i just went out and put a little diesel on the road |
Posts: 2445 Reg: 07-2005
| Do you mean Vin? |
Leon Wright
TryHard WA V8 UZZ31
Posts: 105 Reg: 08-2006
| I wish I could maintain traction in mine sometimes... *reality check* 2nd thoughts no I don't Speaking of Corona's I put 5 diff's in the ST141 Avante (w00t central locking, 5 speed, 2 litre carby ) I had on my P plates in vic. The piston slop was ridiculous when I changed the head gasket, bores we're oval!! My little bro stacked it into a tree and still got a $1000 for it, i pity the poor sod that bought it. It was screwed when I gave it to him! |
