  Soarer Central * Test Post and Forum Issues * Electrical ghosts? Previous Previous    Next Next
Neil Austin
E-UZZ30-ACPVK (V8)
Reg: 01-2006
Sunday, June 03, 2007 - 06:27 pm, by:  Neil Austin (Champion2) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anyone lose a ghost? Only while the drivers door is open, the door lock mechanism engages/disengages at will, like click clack front and back, then clack click take your pick, and there's no typewriter in the boot either. Can anyone help or do I call Ghost Busters?}
Monday, June 04, 2007 - 12:11 pm, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
This ones come up a bit recently. Usually wires in the door hinge area have lost their coating and begun shorting.
Neil Austin
E-UZZ30-ACPVK (V8)
Reg: 01-2006
Monday, June 04, 2007 - 07:11 pm, by:  Neil Austin (Champion2) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Matthew, sounds logical. I'll cancel Ghost Busters.
Tyrone Gillott
robina
v8
Reg: 05-2007
Tuesday, June 05, 2007 - 08:32 pm, by:  Tyrone Gillott (Riggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Neil Austin wrote on Sunday, June 03, 2007 - 06:27 pm:
the ghost is a modual prob it about 300_400 to fix
