  Soarer Central * Test Post and Forum Issues * Test YouTube Embedding.. Previous Previous    Next Next
Mark Ribbans
UZZ-031 V8, 1972 Mazda RX2 Coupe, TE Gemmy
Tuesday, October 28, 2008 - 11:28 am, by:  Mark Ribbans (V8gtsoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just found out how to embed YouTube vids, might want to put this on the formatting page Peter?
Syntax is: \youtube { randomtextbit }
Without the spaces..
Thanks to Mike Beck for showing me this
Soarer Limited UZZ31 V8
Tuesday, October 28, 2008 - 06:07 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for putting this up Mark, as I often forget which order to do the embedding combination in, lucky I remembered it correctly when I showed you.
At least if I forget I can look here. Other wise Peter N has a post some where on the FAQ section for this I think.
Mark Ribbans
Tuesday, October 28, 2008 - 11:04 pm, by:  Mark Ribbans (V8gtsoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No worries Mike. I'm supposed to be an IT guy too! :-)
