> 2000 Lexus SC300 Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Blue/Yellow Car Radio Switched 12v+ Wire: Gray Car Radio Ground Wire: Brown Car Radio Illumination Wire: Green Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger: Pink/Black Car Stereo Amp Trigger Wire: Pink/Blue Car Stereo Amplifier Location: Right side of the trunk. Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Blue Left Front Speaker Negative Wire (-): Red Right Front Speaker Positive Wire (+): White Right Front Speaker Negative Wire (-): Brown Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): N/A Left Rear Speaker Negative Wire (-): N/A Right Rear Speaker Positive Wire (+): N/A Right Rear Speaker Negative Wire (-): N/A
> 1999 Lexus SC300 Car Radio Stereo Audio Wiring Diagram
> 1998 Lexus SC300 Car Radio Stereo Audio Wiring Diagram
> 1997 Lexus SC300 Car Radio Stereo Audio Wiring Diagram
> 1996 Lexus SC300 Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Blue/Yellow Car Radio Switched 12v+ Wire: Gray Car Radio Ground Wire: Brown Car Radio Illumination Wire: Green Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger: Pink/Green Car Stereo Amp Trigger Wire: Pink/Blue Car Stereo Amplifier Location: Right side of the trunk. Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Blue Left Front Speaker Negative Wire (-): Red Right Front Speaker Positive Wire (+): White Right Front Speaker Negative Wire (-): Brown Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): N/A Left Rear Speaker Negative Wire (-): N/A Right Rear Speaker Positive Wire (+): N/A Right Rear Speaker Negative Wire (-): N/A
> 1995 Lexus SC300 Car Radio Stereo Audio Wiring Diagram
> 1994 Lexus SC300 Car Radio Stereo Audio Wiring Diagram
> 1993 Lexus SC300 Car Radio Stereo Audio Wiring Diagram
> 1992 Lexus SC300 Car Radio Stereo Audio Wiring Diagram
> 2000 Lexus SC400 Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Yellow Car Radio Accessory Switched 12v+ Wire: Gray Car Radio Ground Wire: Brown Car Radio Illumination Wire: Green Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: Pink/Black Car Stereo Amp Trigger Wire: Pink/Blue Car Stereo Amplifier Location: Right side of the trunk. Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Blue Left Front Speaker Negative Wire (-): Red Right Front Speaker Positive Wire (+): White Right Front Speaker Negative Wire (-): Brown Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): N/A Left Rear Speaker Negative Wire (-): N/A Right Rear Speaker Positive Wire (+): N/A Right Rear Speaker Negative Wire (-): N/A
> 1999 Lexus SC400 Car Stereo Wiring Diagram
> 1998 Lexus SC400 Car Audio Wiring Diagram
> 1997 Lexus SC400 Car Radio Wiring Schematic
> 1996 Lexus SC400 Car Radio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Blue/Yellow Car Radio Accessory Switched 12v+ Wire: Gray Car Radio Ground Wire: Brown Car Radio Illumination Wire: Green Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: Pink/Green Car Stereo Amp Trigger Wire: Pink/Blue Car Stereo Amplifier Location: Right side of the trunk. Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Blue Left Front Speaker Negative Wire (-): Red Right Front Speaker Positive Wire (+): White Right Front Speaker Negative Wire (-): Brown Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): N/A Left Rear Speaker Negative Wire (-): N/A Right Rear Speaker Positive Wire (+): N/A Right Rear Speaker Negative Wire (-): N/A
> 1995 Lexus SC400 Car Radio Wire Color Codes
> 1994 Lexus SC400 Car Radio Wiring Schematic
> 1993 Lexus SC400 Car Audio Wiring Guide
>1992 Lexus SC400 Car Radio Wiring Chart
