  Soarer Central * Test Post and Forum Issues * LIT UP OR NOT ? Previous Previous    Next Next
Warren Tidyman
uzz31 non turbo 3 litre
Friday, February 10, 2006 - 04:09 pm, by:  Warren Tidyman (Tidywazza) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
should the viewing screen showing temperature / fan speed / air on/off be illuminated at night when my lights are on ?
mine does not backlight in the dark even when park / headlights are on
Wazza
JunkFilterer
Friday, February 10, 2006 - 04:32 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wazza.
You should find just about everything Soarer related that you need on this site. But like the old saying about God, we help those that help themselves, so having a look in the Electrical topic or doing a search would have revealed the answer for you.
They should light up, and you can even get into it and modify the lighting.
http://soarercentral.com/sc-forum/messages/282/33588.html
Lawrence Ostle
tt
Reg: 12-2005
Saturday, February 11, 2006 - 07:31 am, by:  Lawrence Ostle (Lawrence) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Warren, the bottons are illuminated by three bulbs located inside the a/c control unit. I guess all three may have blown, or the connector strip providing power to the bulbs may have worked loose. As Peter notes, there are many information sources on this forum as well as clublexus in the US. Depending on your ability and inclination, you could DIY using one of these info sources, or remove and send it to Mark Paddick (on this forum), and get the bulbs changed for LED's at the same time. If your LCD is 'bleeding', you may want to swap the entire A/C control unt for a 'new' unit from e-bay etc - choices are many...
Warren Tidyman
Thursday, February 16, 2006 - 07:50 pm, by:  Warren Tidyman (Tidywazza) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks to Peter & Lawrence for direction,
so much valuable information at hand and I overlooked it.
