Monday, October 16, 2006 - 07:22 pm, by: David Vaughan(Davidv)
It will not "fvck up the bias" either, actually. The braking system is not that primitive.
The bias will be wrong only in the sense that the braking system could generally be made better by improving the front brakes rather than the rears. The car will still stop perfectly well in either case, just faster in one of them.
Tuesday, October 17, 2006 - 11:14 pm, by: Phil Gibson(Sciflyer)
The caliper part (ie, the bit that has the pistons in it) is identical between TT and V8, but the caliper mounting (the part that bolts the caliper onto the hub) is slightly longer to allow for the larger rotor
Andrew Ferres TryHard WA '86 Cressida V8, '84 Soarer V8, '90 C-F Celsior V8
