Saturday, December 16, 2006 - 08:29 am, by: Juan Landauro(Enigma)
Disc brake replacement (Rotors)
One of my rear brake discs is very close to tolerance thickness and I need to change it for a new one. I would like to have some guidelines in order to do this job. Do I need to change both rear brakes discs at the same time or only the faulty one? Do I also need to change both brake pads or use the old ones or install brand new brake pads? What should I do?
Saturday, December 16, 2006 - 09:24 am, by: Peter Nitschke(Pen)
Might as well replace both rotors. Protex have good cheap replacements - about $90/pair.
If the old pads are OK, and you are happy with them, then use them. There is a lot of info that suggests that new rotors should be run in using old pads.
Sunday, December 17, 2006 - 10:23 am, by: Chris Patterson(Patto)
fitted my celsior front 4 spot calipers and slotted rotors and braided lines yesterday. still bedding in pads but seems to stop a lot better.followed directions of soarer central and didnt have any problems.
Sunday, December 17, 2006 - 09:02 pm, by: Juan Landauro(Enigma)
Juan Landauro wrote on Saturday, December 16, 2006 - 08:29 am:
Please some guide lines to replace the rear brake discs. Rear disc brakes replacement are not as easy as the front ones. Do I change both discs or only one? The rear houses the hand brake mechanism.
Monday, December 18, 2006 - 10:04 am, by: Delan Peiris(Delanx)
Peter where can you get a pair of Protex Rotors for $90? I tried asking few places and the cheapest was $170 for a pair. Anyone got them for cheaper than that?
