Thursday, January 04, 2007 - 06:45 pm, by: Keiran Beytagh(Kezzainc)
I have taken the RR sensor off. It didn't have the same white grease' as the fronts all through the inside. Was quite dry almost dirty.
Is this normal? Not too keen to take the other side off in case i create more problems.
If this isn't normal, what is the most likely hole i have in my hub?
I have a sensor i will be pulling out of a wreaked JZZ30 in a week... From what i can see it seemed best to change the sensor and wire to inside the boot where the plug is. Does anyone know of another way?
Monday, January 08, 2007 - 09:10 am, by: Keiran Beytagh(Kezzainc)
Have to bring this backup guys...
I have read around that there could be a system i can work on that will stop the fault signal been sent to the dash... Just that Mr Reepa's site is no longer going.
Do you guy know how to do this? I just need to get my Warrant then i'll have time to find the real problem....
