  Soarer Central * Brakes * BUSH :: FRONT DISC BRAKE PIN Previous Previous    Next Next
Warren Tidyman
jzz31 non turbo 3 litre
Monday, March 26, 2007 - 03:35 pm, by:  Warren Tidyman (Tidywazza) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
is anyone able to advise me which is the correct part to chase for my JZZ31 front disc brakes ?
where the two slide pins fit into the mounting bracket there is a bush this is what I need.
however when looking up the parts catalogue item number 47769 shows two different part numbers but uses the almost exact same description,
can anyone shed light on the last 2 or 3 letters or has knowledge which bush is correct ?
I would order both numbers but only one is in Toyota australia.
this repair is a result of a broken slide pin that had to be machined out and of course the bush went as well.
Warren
:-) I have a Cadillac, and I am allowed on here :-)
Monday, March 26, 2007 - 07:38 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You need BOTH bushes.. as they ARE different.
Warren Tidyman
Tuesday, March 27, 2007 - 06:28 am, by:  Warren Tidyman (Tidywazza) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thank you, so now I see one bush is smooth one bush is grooved.
are you able to supply both of these bushes ?
#47769-50010 and #47769-50020
am I able to call you ?
Oki Zoubari
south australia
uzz32
Reg: 03-2010
Thursday, February 16, 2012 - 07:50 pm, by:  Oki Zoubari (Oki) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The smooth bush 47769-50020 is 4 weeks from Japan
via Toyota dealer, anyone knows if there is an
aftermarket alternative or where I can get one
quicker, most online sellers only ship within USA.
Matt Newman
soarer tt
Reg: 11-2007
Thursday, February 16, 2012 - 09:42 pm, by:  Matt Newman (Soarersrock) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
why not get one made at a local machine shop? give them the sizes and material type and im sure they can fix you up.
Oki Zoubari
south australia
uzz32
Reg: 03-2010
Thursday, February 16, 2012 - 10:34 pm, by:  Oki Zoubari (Oki) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
what sort of shop would do this?
thanks
