Tuesday, October 25, 2005 - 08:27 pm, by: Craig Moore(Craig)
Yep, you got it there Dave, Wheels or Tits is big money and sooner or later one will cost ya..... Has anyone contacted Neil as I know he posted details on someone who can repair the TRC unit?
Sunday, October 30, 2005 - 06:16 pm, by: Paul Morante(Breaker)
I have had a squeak in my '93 UZZ31 that starts as the fluid increases in temperature, finally purchased the total shebang for $250, about 15 mins after knocking back another offered for $2,450.
Now I'm in the middle of a dissection to understand the wonderful mechanical workings that Toyota inserts into our Soarers. If I can happen across the troublesome seal I may resolve my squeak that I've lived with for 2.5 years.
Sunday, November 20, 2005 - 10:07 am, by: Alan Tam(Uz330)
My 92 UZZ31 Master Brake Cylinder has problem too, It's making some weird noise when i step on the brake and release the brake . What should I do, where can i look for a Used Master cyl, and i think my ABS pump has problem too, anybody know where can i look for used parts
Sunday, November 20, 2005 - 10:33 am, by: Dave Hart(Davyboy)
Try the end of the rainbow. But seriously if you do find a used one it's probably not going to be much better than the one you've got, so get it re-furbished before fitting. Or if you can do without your car for a while have yours re-furbished, but remember that the rest of the system is just as old and you may still have problems so I'd suggest enquiring about costs of new parts then weighing up your options.
Don Bagnall Moderator New Zealand 1991 UZZ30 GT4.0 V8
Sunday, November 20, 2005 - 11:44 am, by: Alan Tam(Uz330)
Thanks for the advice Dave, Where is the end of rainbow? Do they have a web site?. If i want to get a new one, u have any idea how much will it be, and where can i buy it? And how to re-furbish it?
Sunday, November 20, 2005 - 12:38 pm, by: Dave Hart(Davyboy)
Not sure of new price. Try your local Toyota dealer as a starting point then put that price back to the Forum and see if others think it good or bad. As for re-furbishment try a local brake specialist.
Sunday, November 20, 2005 - 03:29 pm, by: Alan Tam(Uz330)
i checked the local dealer, for the new parts need about $2000 something AUD, they don't know the exact price. and the mechanic said re-furbish can't fix my problem, he said i need another master cyl. Anybody know how can i get parts directly from japan? is there any web site can help? Thanks Alot
Monday, November 21, 2005 - 08:03 am, by: Dave Hart(Davyboy)
I'd get another opinion as master cylinders can be re-furbished, but it sounds like your mechanic thinks that the master cylinder isn't the problem so ask him what is the problem. AU$2000+ sounds about right for the whole assembly. That's better than the price I was quoted in NZ ($7k).
Monday, November 21, 2005 - 08:39 pm, by: Shane McInnes(Soarin_tt)
Dave, how did you get your TRC/ABS pump re-furbished? what did you get done to it? did you have the dreadful squeeky noise? if so did you get a fix for that?
My TRC/ABS Master cylinder pump was giving me troubles with the dreadful squeeky noise when i braked and i would get a Brake System warning come up. My mechanic also said they cant be fixed and i got a 2nd hand one.
Monday, November 21, 2005 - 08:59 pm, by: Dave Hart(Davyboy)
I only said that the master cylinder could be re-furbished by having it bored out and sleeved with stainless preferably. Mine is squeaking and the booster pump is running every couple of seconds, may not be related of course. The pump running may be caused by lack of N2 pressure in the pressure vessel and they can be purchased as a separate item for a couple of hundred bucks. What causes the squeak - no idea - maybe fluid passing a seal which may give rise to the pressure drop and the pump running. I also get a brake alarm on the dash, not always but usually within a few minutes of setting off.
Tuesday, November 22, 2005 - 11:04 am, by: Mark Northcott(My91gt)
Hey guys I just had my master cylinder re-kitted and a 2nd hand brake booster, as well as new pads put in and it cost me a total of $690. The pads are bendix ultra's on the front and just bendix on the rear.
So if your mechanic knows his gear he should be able to help you out
Thanks to Neil as well for pointing me in the right direction about brake booster failure.
Tuesday, November 22, 2005 - 03:19 pm, by: Alan Tam(Uz330)
I got a question. Do anybody know will the Master Cylinder from a CROWN MAJESTA E-UZS141 will fit on a Soarer UZZ31 V8 GT? and wat is the part num of both of them?
Tuesday, November 22, 2005 - 05:15 pm, by: Shane McInnes(Soarin_tt)
Yeah Mark yours is different though...you dont have TRC correct? people with TRC have a different master cylinder brake booster than those without TRC.
