Thursday, November 03, 2005 - 11:09 am, by: Anish Varsani(Yomama)
My hand brake is up for adjustment. Just wanted to find out if it needs to be adjusted at the rear brake hub or if it can be adjusted along the cable somewhere.
Thursday, November 03, 2005 - 03:27 pm, by: Dan McColl(Hoon)
From memory there is an adjustment at the handle. Remove the cover and you'll see it. Also try a search because I seem to remember this coming up a while age.
Wednesday, November 16, 2005 - 10:06 pm, by: Rob Middleton(Middo)
Strongly suggest you follow Don's advise and adjust at wheel at first, if you don't as I found out, previous owners mechanic adjusted cable and back hand brake shoe wore down to backing plate. Make sure that the cable has some free play!
