  Soarer Central * Brakes * My car now stops - TT brake upgrade Previous Previous    Next Next
Open in new windowArchive through November 15, 2005Luke Middleton20
Stuart Morgan
tas
limited V8
Wednesday, November 16, 2005 - 05:12 pm, by:  Stuart Morgan (Stumagoo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Really?..... thats fantastic, I can do it and keep my rims then. STOKED!.. Im gonna do it for sure!
Wednesday, November 16, 2005 - 06:09 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Blaine wrote:
quote:
...you should upgrade both the front and rear brake calipers to keep the ABS ratios the same ... I believe this is not an issue with the Soarer TT upgrade
Soarer TT uses a bigger disc with the same caliper at the rear, so you do need to change front and rear to preserve ratios. However, it does not matter if you do not because the ABS has separate channels for each wheel, so balances the braking power front to rear in the same way it balances side to side when you have two wheels in the dirt. This would also apply to the Supra brakes. The issue is opportunity cost in total braking power, not balance in the ABS system. The ABS is self-balancing.
Stuart Morgan
tas
limited V8
Wednesday, November 16, 2005 - 06:17 pm, by:  Stuart Morgan (Stumagoo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks for the pics and info Luke, didnt think I was going to be able to do it, but can see now, I clearly can. Have a full set of tt brakes lined up.... Cant wait!
Luke Middleton
Wednesday, November 16, 2005 - 06:24 pm, by:  Luke Middleton (Spook) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sounds good.
Let us know the outcome
Blaine Hanson
Wednesday, November 16, 2005 - 11:07 pm, by:  Blaine Hanson (Blaine) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I stand corrected. Thanks David. I learn something new on this forum every day.
John Jantzen
Tasmania
V8 UZZ31 Limited
Tuesday, February 07, 2006 - 04:13 pm, by:  John Jantzen (Taslex) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Everyone's saying how easy the conversion to TT brakes is for a V8, however I've just done mine, and there's an issue with the dust/splash shields, which are of course too small to fit the larger TT rotors. I wound up cutting the shields and taking them off - a bit of butchery I would sooner not have done, but as the alternatives were no TT brakes or removing the front wheel bearing holders I went that way. The conversion is great! The TT brakes feel way more responsive and powerful.
Jason Kingsmill
UZZ31 Soarer V8
Tuesday, February 07, 2006 - 06:42 pm, by:  Jason Kingsmill (Jason_k) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Took me less than a minute to break the spot-welds on the dust covers...
I have installed one front and both rear TT brakes...(still waiting for some pad retaining clips for the last front corner) and seems to be a pretty straight-forward job, dis-regarding the rear left corner handbrake not releasing properly.
Yet to give it a real drive, as I have different sized brakes on the front....not something I would think totally safe yet.
John Jantzen
Tasmania
V8 UZZ31 Limited
Wednesday, February 08, 2006 - 08:07 am, by:  John Jantzen (Taslex) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for your comment, Jason. I agree that disposing of the dust shields doesn't take very long, but my view of the difficulty of the job was that I don't like destroying parts to get them off, and if I hadn't done what I did it would have been much more difficult to remove the shields in one piece.
Ian Johnston
UZZ30 GT 4.0
Wednesday, February 08, 2006 - 09:08 am, by:  Ian Johnston (Ted) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just bend them out of the way.
Luke Middleton
Thursday, February 09, 2006 - 12:29 pm, by:  Luke Middleton (Spook) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I used tin snips to remove a small section of the dust shield to be able to remove it. Then used a rubber mallet to straighten the curves a little.
Thursday, February 09, 2006 - 06:37 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
New TT dust shields ARE available ex Toyota.
But I would require your chassis number, BEFORE I can give you an EXACT part number }
Email me with it IF you're interested.......otherwise, you're on ya own HaHa!
JunkFilterer
Thursday, February 09, 2006 - 06:49 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Plus you need to dismantle the hub to fit them.
Thursday, February 09, 2006 - 08:48 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Details! Details!.........Alvays mit da details!.
Oy Vay!.........Just do it already!!!!
