  Soarer Central * Brakes * Ve rims on a soarer Previous Previous    Next Next
Supercharged & Intercooled V8
Tuesday, March 17, 2009 - 11:35 pm, by:  Adam Peterson (President) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
My bro has a set of nice 20" bling rims with dish that i want, only thing is theyre off a VE commodore and the pcd is 5 x 120. How can i use the on the soarer?
Joe Russell
Marlborough
4.0 V8 GT-L(UZZ31)
Reg: 10-2008
Wednesday, March 18, 2009 - 04:32 am, by:  Joe Russell (Joe_r) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wheel spacers with the correct pcd? Might stick out quite far.
Andrew Duaso
Reg: 02-2009
Wednesday, March 18, 2009 - 11:06 am, by:  Andrew Duaso (Andrewd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
5x120 rims can be re drilled through the existing holes down to 5x114.3
i had this done on a set of bboss for my magna, yes they made them in 5x114 but the commodore offset was better than the ones off the shelf.... it could cost you up to $50 per rim and most tyre shops can arrange it
and when they are fitted you can not tell at all
my rims dod over 30K and never had an issue on a heavy car driven hard
see pic they are 5x120 rims now fitted to a 5x114, you cant tell!
Soarer Limited UZZ31 V8
Wednesday, March 18, 2009 - 06:22 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is that supposed to look cool?
Andrew Duaso
Reg: 02-2009
Rating:
Votes: 1 (Vote!)
Wednesday, March 18, 2009 - 06:31 pm, by:  Andrew Duaso (Andrewd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
that is to demonstrate that the rims can be made to work
and your point is what exactly??
Wednesday, March 18, 2009 - 07:03 pm, by:  Adam Peterson (President) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Andrew, did they drill 5 new holes into each rim ?
Andrew Duaso
Reg: 02-2009
Wednesday, March 18, 2009 - 07:17 pm, by:  Andrew Duaso (Andrewd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
they machined out the stock holes then re drilled them and presed in the hardened metal rings,
the pics are the closest pics i have, but basically you could not tell the difference, no one knew.
but if the rims you have are a covered type, it''s much easier to get them redrilled, they basically just drill 5 new holes in them, quite a few big chrome rims you buy come that way
