Tuesday, July 07, 2009 - 01:45 pm, by: Shane Van Ross(Shane_1991)
Guys im stuck need some help...just putting 4 pots on the car...looks to me like the dust/protector thingo will not fit...do i need it...can i remove it...or just trim it to fit...thanks in advance guys...
Tuesday, July 07, 2009 - 05:54 pm, by: Shane Van Ross(Shane_1991)
Peter...cut them off...and removed them...now i think i need washers...for the bolts to make them fit...also got my brakes machined...and i think they have threaded the bottom bolt.. any idea where i can get a replacement...Repco...maybe...thanks
Tuesday, July 07, 2009 - 07:28 pm, by: Matt Newman(Soarersrock)
i think peter means cut them around the radius, as for the bolt is the bolt striped of the nut on the caliper? if its the bolt you should be able to find something at repco or maybe try a bolt supplier. and what are the washers for as far as i know the supra 4 pots don't need washers but the ls400 might be different? best of luck matt
Tuesday, July 07, 2009 - 11:45 pm, by: Shane Van Ross(Shane_1991)
yea thanks matt...saw the tute on the other forum...bolts fit fine...however i think i need washers because the bolts are too long now and they go thru to the rotors...and scrape them...will need a couple of washers...ill try repco..tomorrow..thanks guys
