Tuesday, October 27, 2009 - 10:29 am, by: Matt Petersen(Mattmannz)
Let us know what you think of the pads. I am running stock pads and the four pots are such a massive upgrade over stock I don't know if trick pads are worth it or not.
Friday, October 30, 2009 - 05:00 am, by: James Johnson(Jimbo)
Darryn Dewar wrote on Tuesday, October 27, 2009 - 07:53 pm:
JZZ30/UCF20/JZA80 (NA) all run the same rear setup afaik (Which is also the same caliper from the UZZ30, just a bigger rotor and bracket)
So my current UZZ31 rear calipers will fit on JZZ31 rear discs, and just need to modify the mounting bracket?
Sorry for thread hi-jack here just I have some supra 4 pots for front and some JZZ31 rear's, just have not got around to fitting them yet as I am still hunting for some wheels with enough off set and at the right price.
Saturday, October 31, 2009 - 07:24 pm, by: Darryn Dewar(Mrphreak)
James Johnson wrote on Friday, October 30, 2009 - 05:00 am:
Yup, although personally I wouldn't modify the bracket as it'll just make for a pain at WOF time, and I don't think the JZZ30 ones are that rare....might even be available from Toyota (potentially a small fortune though)
