  Soarer Central * Brakes * TT brakes on V8 Previous Previous    Next Next
Scott Vim
Soarer (1uz) Chaser (1jz)
Reg: 12-2010
Saturday, April 09, 2011 - 03:01 pm, by:  Scott Vim (1uz1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey just did the TT brake swap for the V8 Soarer (front and back). After a bit of reading decided to bend the dust covers back. There is one section where the ball joint is where you can't really bend it. Do you have to cut it here or will bed in that small section or what? Also just wondering if the hand brake needs to be readjusted on the rears it seems like something is sticking a little bit. Also peddle travel has increased. From what I was reading most people have been saying the brakes feel firmer going to the TT setup. Thanks guys.
Ali Saeed
Saturday, April 09, 2011 - 05:52 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
you must bleed the brakes properly if the pedal travel has increased. you can just bend it round the ball joint, should be plenty of clearance
Andy Losurdo
v8 quad cam
Reg: 02-2007
Wednesday, April 27, 2011 - 06:33 pm, by:  Andy Losurdo (Funny_guy77syd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
sorry to interupt but im doing the tt supra brake upgrade to my soarer uzz32
from what i read its a direct bolt on fit but i read that the centre hole on the soarer is 62 mm and the centre hole on the supra 93- 98 rotors off the supra are 60mm holes now do i need to machine the centre hole out to 62mm to sit over the knuckle over the soarer uzz32
please help my emails
a_losurdo@hotmail.com incase i cant find this post again
any info would be apriciated
Scott Casey
soarer v8
Reg: 02-2008
Wednesday, April 27, 2011 - 07:18 pm, by:  Scott Casey (V8soarer_1991) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Should be fine, no one that has replaced their brakes with soarer tt 296mm, celsior 315mm, supra tt 324mm has mentioned that they had a problem?
Allan Langford
Reg: 05-2010
Wednesday, April 27, 2011 - 07:47 pm, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
no modifications are needed to the JZA80 supra rotors, sounds like you may of got MA70/JZA70 rotors by mistake :-(
Steven Anderson
UZZ31 Manual
Reg: 05-2006
Wednesday, April 27, 2011 - 09:18 pm, by:  Steven Anderson (Cusscuss) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yup, 99% sure they are both 60.1mm centre bore.
Nathan Richardson
N.T.
UZZ32 #445 (V8 Supercherged 5Speed. 291RWKW)
Wednesday, April 27, 2011 - 10:31 pm, by:  Nathan Richardson (Richtheblack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Did mine 6 months ago. Only mod is the dust covers.
Andy Losurdo
v8 quad cam
Reg: 02-2007
Friday, April 29, 2011 - 05:34 pm, by:  Andy Losurdo (Funny_guy77syd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks guys apreciate the help
Andy Losurdo
v8 quad cam
Reg: 02-2007
Friday, April 29, 2011 - 05:36 pm, by:  Andy Losurdo (Funny_guy77syd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i was only concerned becaus eon the
www.dba.com.au site the rotor dimentions for centre hub hole was different compared to the jza80 tt 4pot brakes n 2 pot rears
Allan Langford
Reg: 05-2010
Friday, April 29, 2011 - 09:59 pm, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
wht dba part numbers are you looking at?
Andy Losurdo
v8 quad cam
Reg: 02-2007
Saturday, April 30, 2011 - 03:06 pm, by:  Andy Losurdo (Funny_guy77syd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
DBA4718SL
front is DBA4718SR
DBA4719SL
REAR IS DBA4719SL
I TYPED TOYOTA THEN SUPRA THEN 4 POT 2 POT VERSION AND THESE CAME UP WITH DIMENSIONS
now theres are the part numbers for the uzz32 brake rotor
REAR are DBA4746SL
DBA4746SR
FRONT DBA4748SL
DBA4748SR
Andy Losurdo
v8 quad cam
Reg: 02-2007
Saturday, April 30, 2011 - 03:15 pm, by:  Andy Losurdo (Funny_guy77syd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
fronts are 60mm holes on supras
Allan Langford
Reg: 05-2010
Saturday, April 30, 2011 - 05:29 pm, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
62mm on the dba site???
Andy Losurdo
v8 quad cam
Reg: 02-2007
Saturday, April 30, 2011 - 11:10 pm, by:  Andy Losurdo (Funny_guy77syd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ok cheers for that mate looks like a typo the high lighted area shows 16mm fronts
Allan Langford
Reg: 05-2010
Sunday, May 01, 2011 - 10:54 am, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
DBA site rooted it seems!
Andy Losurdo
v8 quad cam
Reg: 02-2007
Sunday, May 01, 2011 - 01:36 pm, by:  Andy Losurdo (Funny_guy77syd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
so the dba site is incorrect
Tim Kroek
Soarer V8
Thursday, May 19, 2011 - 08:08 am, by:  Tim Kroek (Kroek) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
JZA70 is 60 mm centre bores.
JZA80 is 62 mm centre bores.
The Thicknesses on the DBA site are wrong. I work for DBA and have asked the media coordinator to fix these up to avoid confusion.
Gareth Richards
Bristol UK
GTT-L twin turbo auto / Aristo Mk1 TT / Lexus GS300 SE Mk2
Thursday, November 24, 2011 - 12:07 am, by:  Gareth Richards (Garethr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
30-series Soarer, 80-series Supra, 147/16x Aristo/GS, UCF1x/2x Celsior/LS, IS200/300 are all 60.1 centre bore.
Others may be the same but I don't know for certain.
I assume the .1 is for clearance. :-)
Thursday, March 20, 2014 - 05:43 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I know this is really old, but just to confirm, the REAR at least on the JZZ31 centre bore is 62mm. The hub centre itself is 60mm, but it flares out to 62mm at the base, so if you get a rotor with a 60.1mm centre hole, it won't sit flush against the hub.
