Wednesday, June 15, 2011 - 10:36 am, by: Ross Pesina(Ross79)
1993 TT soarer. Amongst other things, I have a handbrake light that refuses to go out on my dash. I've replaced the brake fluid, ensure it's topped up but the light stays on. As a result I cannot use my cruise control. Since most of my driving is up and down the freeway this is very annoying.
I have a sensor in the lid of my reservoir and noticed that the wire that goes into the fluid is broken, I'm assuming this is why I'm getting the error on the dash.
Can someone tell me what value resistor I can plug in to fool it into thinking it's happy?
Thursday, June 16, 2011 - 06:52 pm, by: Ross Pesina(Ross79)
Thanks Jeff. I have no idea why I never thought about trying that. I feel like an idiot trying to work out what resistor to plug in when all I had to do was unplug it! All good now
Ross Pesina TryHard Vic Soarer T, Soarer TT, Supra TT,
Saturday, June 18, 2011 - 10:57 pm, by: Ross Pesina(Ross79)
Spoke too soon. When I drive the car in the morning, it's fine but after about 5mins that handbrake light comes on again!! When I start the car after being warmed up, it stays off. My brake fluid level is full, so not sure what's causing this.
Tuesday, June 21, 2011 - 07:55 am, by: Richard West(Omen666)
Do you have a abs? Mine threw up the handbrake light when driving (and a brake error message initially though). So maybe run a diagnostic? Mine ended up being low accumulator pressure. Just waiting on my recon accumulator from Peter and it should be problem solved.
Tuesday, June 21, 2011 - 08:10 am, by: Ross Pesina(Ross79)
Richard I do have ABS and the accumulator keeps making a noise every few seconds, sounds like that's the problem then. My other soarer has abs but being a 1991 model it's completely different to the setup in this car (1993).
Tuesday, June 21, 2011 - 11:57 am, by: Richard West(Omen666)
Richard West wrote on Tuesday, June 21, 2011 - 07:55 am:
Do you have a abs?
Ahahaha good English Richard :p I would run a diagnostic though, it might be something different, if the motor is running constantly though (motor noise sounds like rubbing or whirring) it's probably the accumulator.
