  Soarer Central * Brakes * Brake problems Previous Previous    Next Next
Mark Lane
N.S.W
sc400 v8 limited
Reg: 11-2011
Friday, April 13, 2012 - 11:22 pm, by:  Mark Lane (Mdl92) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys,
I need help with the brakes on my uzz32, the pedal feels really hard when im braking like the brake assistance is not working. I checked all the vacuum lines but couldn't find any issues. Any ideas on how to fix my brakes would be great, and muchly appreciated!
Thanks heaps in advanced, Mark
Dave Hart
Waikato
UZZ32
Saturday, April 14, 2012 - 02:10 pm, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Are there no alarms coming up?
Is the car stopping normally when you brake?
Mark Lane
N.S.W
sc400 v8 limited
Reg: 11-2011
Saturday, April 14, 2012 - 02:21 pm, by:  Mark Lane (Mdl92) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There aren't any alarms coming up as the dash is not working. There is a beeping sound but i don't know if it is related to the brakes.
The car stops normally, however the pedal is very stiff and you have to push it fairly hard when you try to stop.
Tom Richards
Saturday, April 14, 2012 - 03:44 pm, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
is the pump on the brake master cylinder running all the time? Nitrogen accumulator could be low.
Mark Lane
N.S.W
sc400 v8 limited
Reg: 11-2011
Saturday, April 14, 2012 - 06:08 pm, by:  Mark Lane (Mdl92) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I cant hear the pump running all the time so i assume the nitrogen levels in the accumulator are still ok.
Is there any checks i can run to eliminate the problem?
Thanks, Mark.
Dave Rose
wa
UZZ31 / ML320 CDI
Saturday, April 14, 2012 - 07:06 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mark, do you hear the pump when you first switch on?
Saturday, April 14, 2012 - 09:28 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No alarms, no dash, maybe also no pump?
Fuse?
BMW E36 Coupe 1UZFE V8 340i
Sunday, April 15, 2012 - 11:23 am, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'd say its the nitrogen accumulator...
Vincent Hamilton
Other [Not Listed] - I don't understand the question?
SC400 V8
Reg: 01-2012
Friday, May 18, 2012 - 05:09 pm, by:  Vincent Hamilton (Pistyman) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I need a new accumulator too. I tried to PM Peter Taplin but havnt got a response. Is there any other way to contact him?
Dave Hart
Waikato
UZZ32
Saturday, May 19, 2012 - 05:31 am, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
He's very elusive so good luck with emailing him.
Best to try his w/shop phone or call in like I had to.
Vincent Hamilton
SC400 V8
Reg: 01-2012
Saturday, May 19, 2012 - 09:50 pm, by:  Vincent Hamilton (Pistyman) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
whats his workshop number?
Dave Hart
Waikato
UZZ32
Sunday, May 20, 2012 - 06:50 am, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I don't know but if you know the name of the firm you could look in yellow pages.
Hakan Pasha
Reg: 05-2008
Sunday, May 20, 2012 - 10:29 am, by:  Hakan Pasha (Hakanpasha) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Vince, try
www.soarerparts.com I think Peter has his contact details there.
Friday, May 25, 2012 - 10:15 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just get a new one.
http://soarercentral.com/cgi-bin/sc-forum/show.cgi?tpc=282&post=501717#POST501717
Walter Gillmore
TT JZZ30
Reg: 07-2009
Friday, May 25, 2012 - 07:17 pm, by:  Walter Gillmore (Cl33pa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
sounds like pump issues. i have a pump that goes off constantly but the pedal is still ok. disconnect the pump and the pedal goes hard.
Dave Rose
wa
UZZ31 / ML320 CDI
Saturday, May 26, 2012 - 10:09 am, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Walter, if you disconnect the pump and pedal goes hard ,its the accumulator that has no reserve power stored,running the pump is just keeping the fluid compressed .
