  Soarer Central * Z10/Z20 Soarer Chat * Please help me with my MZ10 Previous Previous    Next Next
Prem Ananth Ganesh
Kuala Lumpur
Soarer (MZ10)
Reg: 11-2006
Wednesday, January 10, 2007 - 09:34 pm, by:  Prem Ananth Ganesh (Soarerlover) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi all.
I have a 1982 MZ10 in malaysia, just owned it 6 months ago...and need some advice on that.
It has a 1G-GTE engine transplanted in it. (auto), and i have some problems with getting some parts for my beauty.
1. What manual transmission can i plug in for the 1G-GTE
2. The max i can go is about 150 in the speedo and i feel that the is so much lack of power, what can i do to boost...the twin turbo seems to be working fine.
3. What sort of suspension can i fix...having problem with what would be the compatible model
4. Where can i get parts (Tail light, front light and back lid)
Your assistance is highly appreciated as i think there is only less than 5 MZ10 in malaysia.
Thanks a million
Simon Jackson
Auckland
UZZ30, bitch!
Reg: 05-2006
Thursday, January 11, 2007 - 07:40 pm, by:  Simon Jackson (Sc400) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
1. A W57 from a GA70 supra will bolt in, you will need the manual driveshaft, clutch, clutch pedal and all the clutch lines aswell.
2. The 1ggte has about 210hp from factory so it isn't really a powerhouse but it should keep pulling to 180 without too much problem.
Fit a boost guage and see what it is boosting, should be 7-10psi i think.
Get a 3inch exhaust made up from the turbos downpipe and then you can turn the boost up to about 14psi to get some more power.
3&4 Are there guys in Malaysia that import aftermaket jap car parts?
Maybe try these guys
http://www.kazutogarage.com/index.php
Andrew Ferres
'86 Cressida V8, '84 Soarer V8, '90 C-F Celsior V8
Friday, January 12, 2007 - 10:03 am, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
GA70 will have the wrong shifter position, so you'll have to source the shifter housing from an RA60, RA65 or MA61 (or manual MZ10)
Simon Jackson
Auckland
UZZ30, bitch!
Reg: 05-2006
Friday, January 12, 2007 - 12:57 pm, by:  Simon Jackson (Sc400) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Got confused with it being a Z20 for a second, shifter position is same as gx71/61 so a w series box from one of those will work with a z10.
Prem Ananth Ganesh
Kuala Lumpur
Soarer (MZ10)
Reg: 11-2006
Saturday, January 13, 2007 - 10:52 am, by:  Prem Ananth Ganesh (Soarerlover) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Would a W58 fit well in her? Thats from the supra as well i think.
There are some used jap parts importers in malaysia, but frankly speaking 9 out of 10 importers dont even know what a soarer is and the 10th guy dont import or have soarer parts. :-(
Would it be possible to plug in a LSD for the MZ10?
-prem-
"We See The World The Way We Are"
Simon Jackson
Auckland
UZZ30, bitch!
Reg: 05-2006
Saturday, January 13, 2007 - 11:34 am, by:  Simon Jackson (Sc400) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
W58 would also work with the correct shifter position which i am fairly sure is the rear position.
What series diff does it have? Have a look at the chassis plate, will be something like T292 or F289 but not necessarily those numbers.
Send the kazuto garage guys an email and they will sort ya out.
Andrew Ferres
Saturday, January 13, 2007 - 11:39 am, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Z10's want the front position, not the rear.
He has an F292 diff.
LSD from an MA61 Supra will bolt in.
