  Soarer Central * Z10/Z20 Soarer Chat * GZ10 to 5 Stud Previous Previous    Next Next
Simon Jackson
Auckland
UZZ30, bitch!
Reg: 05-2006
Tuesday, January 16, 2007 - 08:12 am, by:  Simon Jackson (Sc400) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Has anyone converted a GZ10 to 5x114.3, what hubs/brakes did you use etc..
Andrew Ferres
'86 Cressida V8, '84 Soarer V8, '90 C-F Celsior V8
Thursday, January 18, 2007 - 02:05 pm, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
MS65 front hubs.
MS123 rear hubs.
All use the same bearings, so its bolty/bolty.
Stock front discs will not bolt to MS65 hubs.
MS65 hub centre is 67mm, GZ10 is 60mm. There is plenty of fat in the MS65 hub to machine the centre down to 60mm though (mine has this done)
MS65 hubface sits ~2mm further out compared to GZ10 hubface.
Stock rear disc and calipers bolt up after being redrilled to 5 stud, and having the centre machined out to 67mm (from 60mm) OR you could machine the centre down to 60mm. (I have done this too).
Its a perfect time for a Nissan brake upgrade too.
Simon Jackson
Auckland
UZZ30, bitch!
Reg: 05-2006
Friday, January 19, 2007 - 03:39 pm, by:  Simon Jackson (Sc400) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Fantastic, you are my new best friend!
Andrew Ferres
Friday, January 19, 2007 - 03:54 pm, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://www.toymods.net/forums/showthread.php?t=239
Brake upgrade thread.
I should really add more info on the rear brake upgrade too, just haven't gotten around to it
(I am CrUZida)
