  Soarer Central * Z10/Z20 Soarer Chat * Offset related stuff... Previous Previous    Next Next
Blake Noonan
GZ20 1GG-TEU
Reg: 07-2007
Monday, July 23, 2007 - 06:22 pm, by:  Blake Noonan (Dr_iftx) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey all, i posted this before the site crapped its pants...
and i don't think i got the information i needed before it happened...
18x8.5 on front and 18x9 on the rear and its required offset to keep my guards in original shape.
Chris, i think you were helping me on this before :-)
cheers all
Blake Noonan
GZ20 1GG-TEU
Reg: 07-2007
Monday, July 30, 2007 - 03:06 pm, by:  Blake Noonan (Dr_iftx) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
bump
Matt Dellamalva
JZS147 Aristo, UCF11 Celsior, C33 Laurel
Tuesday, August 07, 2007 - 11:42 am, by:  Matt Dellamalva (Mr_1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I had a 17x8 +31 and 17x9 +36 on my old soarer and they fit no worries with plenty of clearance...so an 18x9 +36 on the rear would fit fine as would an 18x8.5 +30 on the front
Blake Noonan
GZ20 1GG-TEU
Reg: 07-2007
Wednesday, August 08, 2007 - 03:00 pm, by:  Blake Noonan (Dr_iftx) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
would that clear if lowered?
Chris Hills
MZ21
Thursday, August 09, 2007 - 07:44 pm, by:  Chris Hills (4agerolla) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've got 18x8 +30 front and back.. the rears are perfect but the fronts scrub on big dips/bumps, that's also with 15mm of guard rolling and standard ride height.
MR 1JZ your 17x8 +31 didn't scrub, lucky!
Matt Dellamalva
Thursday, August 09, 2007 - 08:13 pm, by:  Matt Dellamalva (Mr_1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
blake that was lowered...so more camber obviously
