  Soarer Central * Z10/Z20 Soarer Chat * Z20 Soarer Parts for sale Previous Previous    Next Next
Boris Siljanoski
LS400 + Soarer.
Reg: 11-2007
Saturday, December 25, 2010 - 07:29 pm, by:  Boris Siljanoski (Z2tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Avaliable are various parts to suit z20 Soarers, Items listed avaliable only.
Not pictured, but also avaliable are Series 1 and Series 2 z20 Tail lights in good condition. Series 1 Taillights - $200. Series 2 Taillights - $400.
Front+Rear Seude Tan seats avaliable too (Great upgrade from cracked leather). Prices Front Seats $300 Pair. Rear - $200.
Other than that, See pictures and list for parts avaliable.
Postage is avaliable to anywhere.
z20 mesh grille, griffin is not attached but included- $50
Bonnet struts z20 - $50
Front Hub Carriers - $100 ea
Rear Hub Carriers - $100 ea
Rear brake pads - $20 pair
z20 Fuel pump - $50
Strut covers - $10
Suspension arms, All straight + Bushes good - $50 each.
High pres solid a/c line with pressure sensors - $20
Cat Converter - $50
Brake master cylinder/reservoir - $50
Working Thermostat 1g-gte - $5
Rear brakes anti-squeel shims - $20
Front Rotors 280mm - $50 both
Diff Output Shafts - $100 ea.
Driveshaft (Have complete not pictured) - $100
Can separate if wanted.
Torque Converter - $50
Series 2 Tan Steering Wheel with Cruise - $50
Series 1 dark Brown Steering Wheel - $50
Glovebox lids Brown + Tan - $50 each.
1g-gte Ignition Leads - $50
Instrument Cluster Surround - $40
Glovebox - $30
Door lock handles and frames - $10 each
"GT TWIN TURBO L" Badge, $10
Door trim pockets - $5 each
1/4 Panel mouldings - $10 each
Centre Sun visor - $10
Licence plate lamps - $20 both.
Reverse light lenses - $10 each
1g-gte fuel pump - $50
Series 2 Overhead lamp panel - $50
Front mudflaps - $20 each
TEMS Computer - $10
Integration relay + Panel - $30
Fuel door - $50
Headlamp relay - $5
rear view mirror - $50
Drivers lock surround - $20
Defog/Cruise/Hazard Switch Panel with switches - $40
Cruise control pump assy - $20
Cruise control motor - $50
Cruise Control Computer - $50
1g-gte head minus cams and buckets, good condition - $150
