  Soarer Central * How-to and Tutorials * Boot struts Previous Previous    Next Next
Craig Morris
S.A
twin turbo
Reg: 10-2006
Thursday, December 25, 2008 - 03:24 pm, by:  Craig Morris (Soarer1985) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey guys i have been at my car for about 30mins now and have no fricken idea how the hell to change over my boot struts can anyone help please!!!
Sunday, December 28, 2008 - 05:18 pm, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Seems to be some argument as to if you need to undo the nut or just unclip it. Consensus was you had to undo the nut but it's lock-tited and painted over so it's very hard to budge.
Mike Dobkin
Essex
Reg: 10-2008
Sunday, December 28, 2008 - 07:45 pm, by:  Mike Dobkin (Razman) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Most people say that applying a little heat softens up the Locktite and makes everything easier. Use a small blowtorch or even a ciggy lighter, get it hot and then use the spanner.
Joshua Rao
JZZ30 vvti GT-L, 94 TT manual (being wrecked), Legnum VR4
Reg: 09-2006
Saturday, April 04, 2009 - 10:45 pm, by:  Joshua Rao (Soaren1) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Craig Morris wrote on Thursday, December 25, 2008 - 03:24 pm:
x 2
Sorry guys but just have no clue. Is there a tutorial somewhere or can someone give me info please?
Do I attack the part that it connects to the boot closest to me or the bit deep in the boot.
How do I attack it? Thanks
Mike Dobkin
Essex
Reg: 10-2008
Rating:
Votes: 1 (Vote!)
Sunday, April 05, 2009 - 02:33 am, by:  Mike Dobkin (Razman) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Are we talking about the same struts? It literally took me 10 minutes to replace mine.
There is tutorial somewhere but basically...
  • Open the boot and prop it
  • Remove the boot liner to get access to the struts
  • Using a small screwdriver lever the clip which holds the strut to a stud on the chassis (when you see it, it is obvious but hard to explain)
  • Remove the nut on the other end of the strut (12mm iirc)This might need some heat but mine came off easily.
  • Remove strut and replace with new one
Anthony Troyano
ny
sc400 V8
Reg: 03-2010
Thursday, June 10, 2010 - 02:00 am, by:  Anthony Troyano (Dramaking408) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys I really need a step by step tutorial preferably with pictures of the boot because I do not have the old one s to compare it too.
Hakan Pasha
Reg: 05-2008
Thursday, June 10, 2010 - 10:32 pm, by:  Hakan Pasha (Hakanpasha) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Matthew Regan wrote on Thursday, June 10, 2010 - 07:55 pm:
are you retarded its not that hard take it to supa cheap even they could do it for you in five minutes
I think he lives in NY (New York?)
Nathan Machin
SC300
Reg: 06-2009
Thursday, June 10, 2010 - 10:49 pm, by:  Nathan Machin (Nthside_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Matthew have a bit of respect for people that arent as informed as you or I dude.
Not cool to be calling someone retarded just cos they cant do or figure out something. Also if you noticed he wouldnt have a clue what the hell you are on about with regards to supa cheap as he is in the USA.
Makes me wonder who the retard is now.
Joshua Rao
JZZ30 vvti auto GT-L, JZZ30 vvti turbo BLK on BLK manual, V8 UZZ31 (being wrecked), Legnum VR4
Reg: 09-2006
Friday, June 11, 2010 - 01:41 am, by:  Joshua Rao (Soaren1) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anthony Troyano
ny
sc400 V8
Reg: 03-2010
Rating:
Votes: 1 (Vote!)
Saturday, June 12, 2010 - 07:33 am, by:  Anthony Troyano (Dramaking408) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey mathew you should listen to your bretheren, for one I'm in new york if you pay a little closer attention instead of preoccupying yourself with being disrespectful,I haven't the slightest clue what supa cheap is. But by the name of it I'm sure that place would be more fit for someone of your caliber. And second of all do watch your mouth when you are addressing me you effin cocka roach,because even thou you are on the other side of the world,I am a strong believer in karma
And people with BIG effin mouths always get what's comming to them.
Even though it would give me great pleasure to be the one to put a damper on that wise little mouth of yours,I guess ill see ya next lifetime j/o!!!!!
Darren Bauer
Reg: 04-2010
Saturday, June 12, 2010 - 10:04 pm, by:  Darren Bauer (Dazmon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Supercheap Auto is good for anyone of any calibre.
Warren Moore
MiGoreng JZZ31 @ 999rwkw
Reg: 01-2010
Saturday, June 12, 2010 - 10:11 pm, by:  Warren Moore (Warreng) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
just for anyone interested in melbourne, there is a good place i dealt with when i first got my soarer and got my original boot struts re-gassed on the spot for about $60 from memory. they are located in fawkner.
http://www.gas-struts.com.au/Welcome.html
Anthony Troyano
ny
sc400 V8
Reg: 03-2010
Sunday, June 13, 2010 - 12:57 am, by:  Anthony Troyano (Dramaking408) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
oh and before I forget that goes for anybody and everybody that thinks there is something retarded about asking questions. Its a shame that in this day and age their are stil people that immature and self absorbed. I would like to share my motto with all of you,and when you spend most of your time on line these should be words to live by; DON'T TELL SOMEONE ON LINE SOMETHING THAT YOU WOULD NOT TELL THEM TO THERE FACE. But unfortunatly not everyone will follow this advice,because the web could be a great place for someone who's words are manifested by a coward. With that said,peace and love to all of those out there that deserve it.
Adam Lonergan
UZZ32 #369 (V8)
Sunday, June 13, 2010 - 09:21 am, by:  Adam Lonergan (Alchemistal) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
In a follow up to Warren's comments.
If you want to save yourself $20 remove and re-install the struts yourself... these sames guys only charged me $40 for a re-gas. Drove-in drove-out in 20 minutes before work one morning.
Sunday, June 13, 2010 - 11:22 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
One of the things I recall from my brief time in NYC was that nobody had any problems saying anything to anyones face :-) And the great thing was it never deteriorated into a fight like it would in these parts of the world. Its a great city, hopefully I can go back some day.
E36 Coupe
Sunday, June 13, 2010 - 04:21 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anthony Troyano wrote on Saturday, June 12, 2010 - 07:33 am:
Well said Anthony!
Also, 95% of the staff at super cheap auto don't know anything about a car, they just sell things off the shelf blindly.
Matthew Sharpe wrote on Sunday, June 13, 2010 - 11:22 am:
Most intriguing.. I look forward to going there someday. Finally go up the Empire State Building.. sadly not the WTC (obviously), but the new one should be done well by then.
Monday, June 14, 2010 - 06:13 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I was there in June 2001 for two weeks only unfortunately. I did go on a bus tour that took us all around the bottom of the WTC but didn't go up. I did go up the Empire State Building which was awesome.
Aaron Casey
Rating:
Votes: 1 (Vote!)
Tuesday, June 15, 2010 - 06:16 pm, by:  Aaron Casey (Blownminiturbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
as mike said one side you need to use a 12 or 13mm spanner to take the ball joint off and the other end on the head there is a metal clip. if you take the pressure off the strut and lever the clip outwards and give it a wriggle it should come off the ball joint
Matthew Regan
w.a.
tt
Reg: 07-2009
Rating:
Votes: 1 (Vote!)
Sunday, June 20, 2010 - 01:03 am, by:  Matthew Regan (Mattregan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
and what is wrong with giving someone some for not knowing how to do something so obvious?its the only way he will learn gotta be cruel to be kind
Sunday, June 20, 2010 - 02:19 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Matthew Regan, go away.
Nobody should have to put up with your bad attitude.
E36 Coupe
Sunday, June 20, 2010 - 09:53 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Peter Nitschke wrote on Sunday, June 20, 2010 - 02:19 am:
Exactly.
John Khanh
Saturday, February 28, 2015 - 08:36 pm, by:  John Khanh (Bigjohn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thread Revival!
A brand new pair of gas struts for the boot can be had for $30.50 delivered Australia wide through Gas Strut Guys on eBay.
I bought a pair for my Micra and they were fantastic quality and highly pressurised. I had to hold onto the tailgate on that car as it flung up.
Guess I'll be buying a pair for $30.50 for my new Soarer.
Jamie Lauren
Reg: 01-2015
Tuesday, August 18, 2015 - 07:40 pm, by:  Jamie Lauren (Noisy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
+1 for Gas Strut Guys.
$30 including standard shipping arrived within 48 hours. Good service.
Bryan Flemming
Reg: 07-2015
Saturday, September 12, 2020 - 02:40 pm, by:  Bryan Flemming (Flyan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The new struts are a clip on style from the 'Gas Strut Guys' where the original fitment only clip at the one end and the other is a press fit onto a ball which is bolted to the car.
Removal; The ball/bolt end can be levered off while on the car, if this can't be done then using a 12mm spanner remove the bolt/ball end. This will be tight if it is still the original fitment as it is loctited, make sure to use a good quality spanner so not to round the bolt when undoing it. Once off use a claw hammer and lever the bolt/ball from the old strut. The other end clips onto a shaft, using a flat screwdriver lever the clip to bend it up then the strut will slide off the shaft.
Replace; Fit the bolt/ball back to the car then clip on the new strut, repeat for other side and your done. Now you can climb out of the boot. :-)
