  SoarerCentral * General Soarer Chat * Whats in the boot? Previous Previous    Next Next
Open in new windowArchive through August 25, 2005Jeff Harper16
Thursday, August 25, 2005 - 06:25 pm, by:  Don Bagnall Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Emanuel Spinola
Thursday, August 25, 2005 - 06:39 pm, by:  Emanuel Spinola Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jeff Harper wrote on Thursday, August 25, 2005 - 06:08 pm:
over the flaming remains of any skyline engine bay.
can alternatively be substituted with
over the flaming remains of any Nissan engine bay.
based on my observations....
Luke Nieuwhof
Thursday, August 25, 2005 - 11:12 pm, by:  Luke Nieuwhof Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm pretty sure sandwich/jaffle toaster was the original intention for this piece, the wheel chock aspect is just a nifty side benefit.
Andrew Ferres
Cressida V8
Friday, August 26, 2005 - 11:53 am, by:  Andrew Ferres Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Make sure you remove the jaffle before using it to hold up the car.
Or alternatively, make sure its not holding up the car before using it a jaffle maker.
Maybe this is why you have 2?
Friday, August 26, 2005 - 12:23 pm, by:  David Vaughan Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Two? I got only one. Still, if I cook the jaffle a bit longer I can use that on the other side.
Ian Johnston
UZZ30 GT 4.0
Friday, August 26, 2005 - 12:52 pm, by:  Ian Johnston Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is it a jaffle, 0r just a load of waffle?
Friday, August 26, 2005 - 04:38 pm, by:  Don Bagnall Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
WHAT, prey tell....is a Jaffle?, is it like what we in Baa Baa land call a Waffle?.
OR, as I suspect, a load of colonialised "Bull-pucky" .
Disclaimer: No actual Jaffles / Waffles / Bulls were harmed in the making of this post.
Michael James
V8 UZZ31 Limited
Friday, August 26, 2005 - 08:28 pm, by:  Michael James Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jaffle = toasted sandwich
Friday, August 26, 2005 - 08:45 pm, by:  Don Bagnall Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Excellent......thank you Michael, we in NZ still call them "Toasted Sandwich's".......much like the rest of the NORMAL world, I suspect
Emanuel Spinola
Friday, August 26, 2005 - 08:59 pm, by:  Emanuel Spinola Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Perhaps not mate :-)
Google Jaffles
Friday, August 26, 2005 - 09:08 pm, by:  Don Bagnall Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Interesting
David Vaughan (Davidv)
Saturday, August 27, 2005 - 07:59 am, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
We have the old single jaffle iron which you put on the stove (4th pic down in the left column). The "real" ones my parents had were round rather than pandering to modern square bread, and for entertainment we would cook with them by sticking the end in a fire, which is for what they were originally designed. Much better than a toasted sandwich because the contents get hotter and nothing drips or falls out while eating.
Go on Don, buy one. You know you are wanting it.
Mike Triggs (Mikeandimah)
Saturday, August 27, 2005 - 08:25 am, by:  Mike Triggs (Mikeandimah) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Actually, a jaffle is different to a toasted sandwich, because the jaffle iron squashes the edges of the bread together, sealing them (hopefully!). So the end product is akin to a pie. Modern electric "snack makers" are similar except they're electric, not designed to put in the fire
