Sunday, October 01, 2006 - 09:50 pm, by: Bill Bogiatzis(Boggie23)
I would say anything around 140-200 for oils, filters, and general check of everything else top up of fluids etc is reasonable depending on the quality of the oils.
Anything over 200 is a bit of a rip though. Even going near 200 is on the higher side.
Sunday, October 01, 2006 - 11:41 pm, by: Kimberly Burke(Burkey86)
ok well for a service which was replace engine oil, and filter. check steering and suspension. Check brakes and other fluids. Lights wipers and tyres $255
Monday, October 02, 2006 - 08:07 am, by: Matthew Sharpe(Madmatt)
For a normal service on my V8 to match the Waranty requirements it was $200. This included cooling system pressure test, compression test, plug check as well as all the other bits and pieces. As soon as the waranty expired I did my own servicing, which usually came to about $70 and a small mess to clean up =)
Monday, October 02, 2006 - 09:30 am, by: Neil Griffiths(Aussiesc)
I charge about $140 ( Includes Penrite PRO 10 Oil & MAX Oil Filter )Also includes inspection of all undercarriage / fluids etc ( Bar the Diff )New Sump Plug Washer, A worksheet of what I have done & found, door check strap and lock lube, Tyre Pressures checked, Tyre Shine ( Silicon ) Windscreen cleaned. Only extra on a standard service will be * correct rubber * wiper inserts @ $17.60 if needed or incorrect ones installed. Service includes free quality washer additive, steering / brake fluid top up if needed.
Monday, October 02, 2006 - 07:41 pm, by: Ben Socratous(Socrates)
Toyota here in Adelaide charge about $15/hr more than the average mechanic's rates. They justify this by saying that no-one knows your toyota like them. This may be well and true for the Oz delivered models, but I would tend to think that there are a lot more people that know imported toyotas better than your local toyota dealer.
