  SoarerCentral * General Soarer Chat * Power Steering Reservoir Previous Previous    Next Next
Jeff Wilkins
JZZ30 GT-TL
Sunday, November 19, 2006 - 06:00 pm, by:  Jeff Wilkins (Calin) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anybody have the part number for the power steering fluid reservoir by any chance? My mongrel has a very slow leak around the rim, but a little fluid can make a lot of mess lol.
Ben Socratous
I am the fibreglass/kevlar/carbonfibre king!
Sunday, November 19, 2006 - 06:53 pm, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Drop Don Bagnall a PM with your chassis number and he should be able to hook you up, he is the part # guru
Alternatively you could get an aftermarket fooly sik blue anodised one...
Rehan Bandara
Reg: 10-2006
Sunday, November 19, 2006 - 07:33 pm, by:  Rehan Bandara (Parsec) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
what's an aftermarket reservoir worth?
212Kw @ 8psi MANUAL Super Charged UZZ31 :-)
Sunday, November 19, 2006 - 08:04 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The rim has a rubber ring under the lip..
Take it off or try crimping it down some more.
Even some Triple Bond around it can stop the leak.
Jeff Wilkins
JZZ30 GT-TL
Sunday, November 19, 2006 - 08:11 pm, by:  Jeff Wilkins (Calin) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah Neil, I was planning to take it off, re-pop the lid and throw a new o-ring in. Would like to price a replacement part though. IF the price isn't insane (quite a possibility) I'll throw a new one on.
Sunday, November 19, 2006 - 08:44 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jeff,
Yours being a 93 model I will give you two numbers, as they changed part numbers part way through 93.
44360 - 24040 5/1991 - 4/1993
44360 - 24041 4/1993 - 5/1994
If as Ben says you give me your full chassis number, I will confirm which one is correct.
Ben Socratous
Sunday, November 19, 2006 - 09:28 pm, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ben Socratous wrote on Sunday, November 19, 2006 - 06:53 pm:
There was meant to be a hint of sarcasm there. If you think you need some engine bay bling, they are about $80-100 and available at autobarn and similar stores.
