  SoarerCentral * General Soarer Chat * BOV Help Previous Previous    Next Next
Joel Moore
91 Soarer TT
Reg: 10-2006
Wednesday, December 27, 2006 - 05:05 pm, by:  Joel Moore (Ttsoai2ei2) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
my tt is getting turbo blow back through the filter which is bad apparently. i would like to buy a blow off valve but not sure which one i need to get. can i run both turbos on one valve??? also how do i know what kind of sound i will get. have heard some 'different' ones
Ben Socratous
I am the fibreglass/kevlar/carbonfibre king!
Wednesday, December 27, 2006 - 05:22 pm, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What is wrong with your stock one? That does a perfect job up to about 18psi, as long as it is not cactus.
I have a turbosmart vee-port, does the job and produces the classic 'ptssssh' sound, and is a little less noisy than the bovs with the trumpet on the side, ie less cop attention :-)
Gary Morriss
Wednesday, December 27, 2006 - 06:00 pm, by:  Gary Morriss (Gaza) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Joel..whats happend to the factory BOV?
94 UZZ31 (V8) / 96 JZZ30 (TT)
Thursday, December 28, 2006 - 03:34 am, by:  Vinh Bui (Hyudsjk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You will only need one BOV.
As for the sound, try here:
www.blowoffvalves.com
Joel Moore
91 Soarer TT
Reg: 10-2006
Thursday, December 28, 2006 - 10:57 am, by:  Joel Moore (Ttsoai2ei2) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
my tt is getting turbo blow back through the filter which is bad apparently. sounds exactly the same as a bov. i dont have any aftermarket bov that i can see either
Thursday, December 28, 2006 - 11:38 am, by:  James Harris (Haro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
dont worry bout it,
its just coz you are using a pod filter ?? It makes induction/turbo spool/chatter a lil louder.
If you want a BOV and you have stocko piping, just buy one off an online retailer as a kit and slap it on. I bet your pod will still emit the same noise tho !! just may be hidden a lil by the offensive
PPPTTTTCCHHHHH !
Thursday, December 28, 2006 - 01:21 pm, by:  Vinh Bui (Hyudsjk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What do you mean exactly by 'turbo blow back'?
Kim Nguyen
Thursday, December 28, 2006 - 01:28 pm, by:  Kim Nguyen (Kim) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think he is talking about the POD filter noise Vinh. The noise I use to get confused with. tch tch tch noise when you come off the throttle.
Am I correct or way off as usual?
Thursday, December 28, 2006 - 01:42 pm, by:  Vinh Bui (Hyudsjk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Are you describing the 'flutter' noise? If so, I've been told that it's not very good for the turbos as it is known as compressor surge.
I've only heard about one or two Soarers with this noise, so I don't think it could be a good thing.
Just buy the right kit for your car, or at least get something that won't harbour any compressor surge.
Kim Nguyen
Thursday, December 28, 2006 - 02:05 pm, by:  Kim Nguyen (Kim) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Only 2 soarers with that noise? Geez I am going to have to record this noise now, I am kind of worried about it. I thought it was just POD filter noise from air going back through the POD when the throttle body closes. That is what I was told anyways.
Anyways, Joel.. A guy I know has just a cheap china BOV on his R32 Skyline and it makes a big WHOOOSH noise which is what I like, unlike the HKS SSQ which is like a high pitched noise this had a bit of volume.
Danny Dinh
GT T
Thursday, December 28, 2006 - 05:51 pm, by:  Danny Dinh (Xtc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
no BOV can completely vent un-used compressed air. You will notice different noises with different setup. NO doubt the single turbo setup will give you louder noise especially if you have a big FMIC. It will give you the fluttering noise regardless of how many BOV you have.
I think the stock BOV is a very good item so if it's still working stick with it.
Jeff Smith
TT Limited 13.295@102mph\165kph,13psi
Thursday, December 28, 2006 - 07:41 pm, by:  Jeff Smith (Mozzie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I get a little compressor surge but only on low throttle boost but when I snap shut on high boost I get that whoosh you discribe.It is a combination of the BOV(Turbosmart v-port2 bov),Pod filter(steel mesh pod,Justjap $30 special) and FMIC(Hybrid)
Kim Nguyen
Friday, December 29, 2006 - 01:52 am, by:  Kim Nguyen (Kim) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I usually get that noise on low throttle also, I shall figure out how to record the noise and post it up for all to hear!
Friday, December 29, 2006 - 06:46 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No thanks, I get enough of that from the dickheads who drive past my house at 3am on Saturday morning.
Shane McInnes
JZZ30 GT-TL Manual
Friday, December 29, 2006 - 08:03 am, by:  Shane McInnes (Soarin_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just post it in the Twin Turbo Section Kim
Friday, December 29, 2006 - 09:06 am, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Matthew Sharpe wrote on Friday, December 29, 2006 - 06:46 am:
Tell me about it. We've got a bunch of idiots who ALL own R32 & 33 Skylines living in a rental dump up the road from us, and they insist on doing major burnouts n' stuff at 2am on Thursday & Friday nights.
I mighta fixed the problem though, as I found out the name of the property owner and rang him at 3am the other morning with the message that everytime WE got woken up, HE would get a phone call from ME.
He wasn't well pleased but hopefully he'll sort his idiot tenants out (or change his phone number HeHe!)
Friday, December 29, 2006 - 10:27 am, by:  James Harris (Haro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
aaww nah.. that would be sweet as bro !
** on another note, the skylines with stocko turbos and just a pod sound pretty good whilst inducting / spoolin up i reckon. Used to love that in my old skylines (especially the one with the Apexi Twin Chamber BOV... LOUD)
