  SoarerCentral * Transmission * Shift Kit Installation Instructions Previous Previous    Next Next
Rhys Mottram
Mark II Tourer V TT
Wednesday, December 28, 2005 - 12:40 pm, by:  Rhys Mottram (Onejzx90) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just wondering if anyone has the fitting instructions sitting around for the A340 TT gearbox, as i have one fitted to the box in my car that i bought and the box has died and need to swap over into new box and was told its not that hard, but that i should source the instructions aswell ..
Rhys
Chris Davey
Corona
Wednesday, December 28, 2005 - 02:10 pm, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
if this is the MV shift kit that has valve body mods and a different spring on the accumulator then it is easy.
I don't know if it is the b2 or c2 accumulator spring you change.
Here is a link to how to do your own shift kit so you can follow all that except for shimming the accumulators and instead of putting the stock valve body back on you put the modded one.
http://jkwebdesign.net/lsocbb/viewtopic.php?t=1915
Simon Triantafillou
Soarer Turbo
Wednesday, December 28, 2005 - 02:31 pm, by:  Simon Triantafillou (Soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://www.planetsoarer.com/shiftkit/DIYinstall_files/DIYinstall.htm
My install instructions hosted on Planet Soarer. This was a TT auto.
Rhys Mottram
Mark II Tourer V TT
Wednesday, December 28, 2005 - 02:32 pm, by:  Rhys Mottram (Onejzx90) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cheers guys, yeh it is the MV one
Trent Osborne
florida
sc300 na.sc400tt
Reg: 11-2006
Wednesday, January 10, 2007 - 06:11 am, by:  Trent Osborne (Sc250tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
lovely .i have to change my no.1 solenoid so im gonna have to rip my tranny dow this weekend to do this shift kit mod .
Sam Avery
south australia
celsior v8
Reg: 10-2006
Wednesday, January 10, 2007 - 10:22 pm, by:  Sam Avery (Samavery) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
can you please let me know how much the shift kit cost..?
i would like to get one for my celsior.
