  SoarerCentral * General Soarer Chat * Cant source these fasteners- 12pt, 8mm, grade 8 or 10.9 Previous Previous    Next Next
Aaron Mead
Tuesday, January 30, 2007 - 07:19 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anyone know where to find these. Ive spent a couple of days on the net trying to find suppliers, seems like Coventry, Ajax, Bremmick and even revolution racegear cant source them:
Aaron Mead
Tuesday, January 30, 2007 - 07:20 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Oh flanged and serrated Grade 8 or 10.9 Nuts would be good too....
212Kw @ 8psi MANUAL Super Charged UZZ31 :-)
Tuesday, January 30, 2007 - 07:30 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://www.google.com.au/search?hl=en&q=specialty+fastners&btnG=Google+Search&meta=cr%3DcountryAU
Tuesday, January 30, 2007 - 07:31 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://www.hotfrog.com.au/Products/Bolts
Aaron Mead
Tuesday, January 30, 2007 - 07:36 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ahh, all the results are purple. BECAUSE IVE BEEN THERE ALREADY!!!!!! HAHHAHAHAH
Nah, seriously Neil, ive rang around the country, from perth to QLD.
Best option so far is to order 1000 units from the USA or 100 units minimum from Brazil, 8 weeks wait. Its looking like being cheaper to buy the 5 packs of ARP fasteners.
Aaron Mead
Tuesday, January 30, 2007 - 07:37 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Even tried three rim repair joints, who pointed me in the direction of people Ive spoken to already!!!
Ebay.com has a very similar product to the OZ fastener, used to secure AMG, Sparco and OZ rims. 5bux each, no nuts!
Tuesday, January 30, 2007 - 08:26 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Oh,,These are for Mag Wheels ?
I can ask the Wheel Factory down here !
How many you need ?
Why not buy some old mags and nik em !
Aaron Mead
Tuesday, January 30, 2007 - 09:20 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ive broken 5 so far, so Id need to at least replace them. Torquing them up to 25nm with loctite lube is okay on all but a few, and I fear that a few more may die along the way. I get the feeling they've been stretched, but have no way of measuring. Im thinking about replacing all 116.
I tried Alliance Rim Repair in perth and Wheel Collision centre in the US and A. They have a similar item, but with an 11 point head??
Active V8 and a Factory Manual XF.
Friday, February 02, 2007 - 04:27 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I could probably find some imperial ones.
Aaron Mead
Friday, February 02, 2007 - 08:34 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Imperial is good!
Friday, February 02, 2007 - 08:49 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Righto. I'll have a look on Monday for some 1/4" (6.35 mm) ones.
