  SoarerCentral * Transmission * Auto Gear box Problem - Please help !! Previous Previous    Next Next
Nat Vann
Tuesday, February 20, 2007 - 02:28 pm, by:  Nat Vann (Redlineraver1) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi every one,
JZZ30 1991 TT
Find attached a photo of what is displayed when i set off the Auto Gear Box Diagnostic function.
For the life of me i cant find anything on this message.PLEASE HELP
Whats happening in the first place is that the gear box is holding on to first gear way way to long no other gears just 1st, but if you release the throtal just a bit it changes in to 2nd, But it all so slips if changed back to 2nd from Drive and put your foot down.
Was hoping just to get an error message of maybe first or second solenoid but NO it has to be a pain.
Darryn Dewar
Gisborne
UZZ30 Soarer
Tuesday, February 20, 2007 - 03:56 pm, by:  Darryn Dewar (Mrphreak) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That'd be the message to say you're in Diag mode.
Benjamin Burgess
Toyota Soarer GT-TL, Toyota Corolla Conquest
Thursday, February 22, 2007 - 08:05 am, by:  Benjamin Burgess (Jampac) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sounds like your gearbox needs a rebuild or maybe a shift kit might help. One thing that well cost you nothing and is worth trying is to tighten up the line pressure cable that runs off the throttle body to the gearbox.
